Datasheet ADG1519 (Analog Devices) - 4
Description3.8 Ω On-Resistance, SPDT Switch
Pages / Page15 / 4 — ADG1519. SPECIFICATIONS. Table 1. Parameter. 25°C. –40°C to +85°C. −40°C …
File Format / SizePDF / 673 Kb
ADG1519. SPECIFICATIONS. Table 1. Parameter. 25°C. –40°C to +85°C. −40°C to +125°C. Unit. Test Conditions/Comments
ADG1519 SPECIFICATIONS Table 1 Parameter 25°C –40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments
link to page 11 link to page 4 link to page 11 link to page 4 link to page 4 link to page 4 link to page 4 Data Sheet
ADG1519 SPECIFICATIONS Table 1. Parameter 25°C –40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments
−3 dB Bandwidth 95 MHz typ RL = 50 Ω, CL = 5 pF, see Figure 274 Insertion Loss 0.3 dB typ RL = 50 Ω, CL = 5 pF, frequency = 1 MHz; see Figure 274 Source Capacitance, CS (Off) 27 pF typ VS = 0 V, frequency = 1 MHz1 Drain Capacitance, CD (Off) 58 pF typ VS = 0 V, frequency = 1 MHz1 CD, CS (On) 129 pF typ VS = 0 V, frequency = 1 MHz1 POWER REQUIREMENTS VDD = +5.5 V, VSS = −8.8 V Positive Supply Current, IDD 0.001 µA typ Digital inputs = 0 V or VDD 1.0 µA max Negative Supply Current, ISS 0.001 µA typ Digital inputs = 0 V or VDD 1.0 µA max 1 VS is the analog voltage for Terminal SA or Terminal SB and IS is the analog current for Terminal Sx. 2 VD is the analog voltage on Terminal D. 3 VIN is the IN voltage, and VGND is the GND voltage. 4 RL is the load resistance and CL is the load capacitance. 5 VSA is the Source A voltage, and VSB is the Source B voltage. 6 RS is the source resistance.
CONTINUOUS CURRENT PER CHANNEL, SX OR D Table 2. Parameter 25°C 85°C 125°C Unit Test Conditions/Comments
CONTINUOUS CURRENT PER CHANNEL Dual Supply VDD = +4.5 V, VSS = −7.2 V 8-Lead LFCSP (θJA = 64.9°C/W) 310 180 95 mA maximum
analog.com Rev. 0 | 4 of 15
Document Outline Features Applications General Description Functional Block Diagram Product Highlights Specifications Dual Supply Continuous Current Per Channel, Sx or D Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Test Circuits Terminology IDD ISS VD and VS RON RFLAT ON IS Off ID Off ID and IS On VINL VINH IINL and IINH CS Off CD Off CD and CS On CIN tON EN tOFF EN tTRANSITION TD Charge Injection Off Isolation Crosstalk Bandwidth Insertion Loss THD + N THD AC PSRR Applications Information Power Amplifier Gate Drive Power Supply Rails Power Supply Recommendations Outline Dimensions Ordering Guide Evaluation Boards
