Datasheet ADG5298 (Analog Devices) - 6
DescriptionHigh Temperature, High Voltage, Latch-Up Proof, 8-Channel Multiplexer
Pages / Page20 / 6 — ADG5298. Data Sheet. 36 V SINGLE SUPPLY. Table 4. Parameter. Symbol1. …
File Format / SizePDF / 570 Kb
ADG5298. Data Sheet. 36 V SINGLE SUPPLY. Table 4. Parameter. Symbol1. Test Conditions/ Comments1. Min Typ2. Max Unit
ADG5298 Data Sheet 36 V SINGLE SUPPLY Table 4 Parameter Symbol1 Test Conditions/ Comments1 Min Typ2 Max Unit
link to page 14 link to page 14 link to page 14 link to page 14 link to page 15 link to page 15 link to page 15 link to page 15 link to page 15 link to page 14 link to page 14 link to page 14 link to page 13 link to page 13 link to page 16
VDD = 36 V ± 10%, VSS = 0 V, GND = 0 V, and −55°C ≤ TA ≤ +210°C, unless otherwise noted.
Table 4. Parameter Symbol1 Test Conditions/ Comments1 Min Typ2 Max Unit
ANALOG SWITCH Analog Signal Range VSS VDD V On Resistance RON VS = 0 V to 30 V, IDS = −1 mA, see Figure 31; 260 350 Ω for maximum RON, VDD = 32.4 V, VSS = 0 V On-Resistance Match Between Channels ΔRON VS = 0 V to 30 V, IDS = −1 mA 1.5 10 Ω On-Resistance Flatness RFLAT (ON) VS = 0 V to 30 V, IDS = −1 mA 55 110 Ω LEAKAGE CURRENTS VDD = 13.2 V, VSS = 0 V Source Off Leakage IS (off) VS = 1 V/10 V, VD = 10 V/1 V, see Figure 32 −8 ±0.005 +8 nA Drain Off Leakage ID (off) VS = 1 V/10 V, VD = 10 V/1 V, see Figure 32 −60 ±0.005 +60 nA Channel On Leakage ID (on), IS (on) VS = VD = 1 V/10 V, see Figure 30 −70 ±0.01 +70 nA DIGITAL INPUTS Input High Voltage VINH 2.0 V Input Low Voltage VINL 0.8 V Input Current IINL or IINH VIN = VGND or VDD −0.1 +0.002 +0.1 µA Digital Input Capacitance CIN 3 pF DYNAMIC CHARACTERISTICS3 Transition Time tTRANSITION RL = 300 Ω, CL = 35 pF, VS = 18 V, see Figure 36 170 320 ns On Time tON (EN) RL = 300 Ω, CL = 35 pF, VS = 18 V, see Figure 38 150 265 ns Off Time tOFF (EN) RL = 300 Ω, CL = 35 pF, VS = 18 V, see Figure 38 180 265 ns Break-Before-Make Time Delay tD RL = 300 Ω, CL = 35 pF, VS1 = VS2 = 18 V, 20 55 ns see Figure 37 Charge Injection QINJ VS = 6 V, RS = 0 Ω, CL = 1 nF, see Figure 39 0.3 pC Off Isolation RL = 50 Ω, CL = 5 pF, f = 1 MHz, see Figure 34 −86 dB Channel to Channel Crosstalk RL = 50 Ω, CL = 5 pF, f = 1 MHz, see Figure 33 −80 dB −3 dB Bandwidth RL = 50 Ω, CL = 5 pF, see Figure 35 105 MHz Source Capacitance, Off CS (off) VS = 6 V, f = 1 MHz 2.7 pF Drain Capacitance, Off CD (off) VS = 6 V, f = 1 MHz 32 pF Source/Drain Capacitance, On CD (on), CS (on) VS = 6 V, f = 1 MHz 35 pF POWER REQUIREMENTS VDD = 13.2 V Supply Current Positive IDD Digital inputs = 0 V or 5 V, see Figure 28 80 155 µA Negative ISS Digital inputs = 0 V or 5 V, see Figure 29 10 20 µA Ground Current IGND Digital inputs = 0 V or 5 V 80 155 µA Supply Range VDD/VSS GND = 0 V, VSS = 0 V 9 40 V 1 See the Terminology section. 2 TA = 25°C, except for the analog switch and power requirements values, where TA = 210°C. 3 Guaranteed by design, not subject to production test.
CONTINUOUS CURRENT PER CHANNEL (Sx OR D) Table 5. Parameter Test Conditions/Comments 175°C 210°C Unit
CONTINUOUS CURRENT (Sx OR D) θJA = 70 °C/W VDD = +15 V, VSS = −15 V 10 10 mA maximum VDD = +20 V, VSS = −20 V 10 10 mA maximum VDD = 12 V, VSS = 0 V 6 6 mA maximum VDD = 36 V, VSS = 0 V 10 10 mA maximum Rev. 0 | Page 6 of 20 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL-SUPPLY ±20 V DUAL SUPPLY 12 V SINGLE SUPPLY 36 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL (Sx OR D) ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY THEORY OF OPERATION TRENCH ISOLATION APPLICATIONS INFORMATION OUTLINE DIMENSIONS ORDERING GUIDE
