Datasheet ADG798-KGD (Analog Devices)
DescriptionHigh Temperature, Low Voltage, 8-Channel Multiplexer
Pages / Page13 / 1 — High Temperature, Low Voltage,. 8-Channel Multiplexer. Known Good Die. …
File Format / SizePDF / 822 Kb
High Temperature, Low Voltage,. 8-Channel Multiplexer. Known Good Die. ADG798-KGD. FEATURES. METAL MASK DIE IMAGE
Datasheet ADG798-KGD Analog Devices
High Temperature, Low Voltage, 8-Channel Multiplexer Known Good Die ADG798-KGD FEATURES METAL MASK DIE IMAGE A0 A1 Extreme high temperature operation up to 210°C 3.0 V to 5.5 V single supply 1 24 ±2.5 V dual supply 10 Ω on resistance, maximum 23 A2 EN 2 2 Ω on-resistance flatness, maximum 12 ns transition time VSS 3 22 GND Single 8:1 multiplexer Low power consumption TTL-/CMOS-compatible inputs V 4 21 V SS DD APPLICATIONS S1 5 20 S5 Downhole drilling and instrumentation Avionics NC 6 19 NC Heavy industrial High temperature environments S2 7 18 S6 S3 8 17 S7 NC 9 16 NC NC 10 15 NC 11 12 13 14
1 03 7-
S4 D D S8
87 14 Figure 1.
GENERAL DESCRIPTION
The ADG798-KGD is a member of a growing series of high The ADG798-KGD is a low voltage, CMOS, analog multiplexer temperature qualified products offered by Analog Devices, Inc. designed to operate at very high temperatures up to 210°C. The For a complete selection table of available high temperature ADG798-KGD switches one of eight inputs (S1 to S8) to a products, see the high temperature product list and qualification common output (D) as determined by the 3-bit binary address data available at www.analog.com/hightemp. lines (A0, A1, and A2). An EN input on the device enables or Additional application and technical information can be found disables the device. When the device is disabled, all channels are in the ADG798 data sheet. Known Good Die (KGD): these die switched off. are fully guaranteed to data sheet specifications. The ADG798-KGD features low power consumption and a
PRODUCT HIGHLIGHTS
3.3 V to 5.5 V operating supply range. All channels exhibit 1. Single-Supply/Dual-Supply Operation. break-before-make switching action, preventing momentary The ADG798-KGD is fully specified and guaranteed with shorting when switching channels. These switches are designed +3.3 V/+5 V single-supply rails and ±2.5 V dual-supply rails. with an enhanced submicron process that provides low power 2. Low RON. dissipation, high switching speed, and very low on resistance. The RON of the ADG798-KGD is specified at 5 Ω, typical, at The on resistance (RON) is a maximum of 10 Ω and is closely 210°C. matched between switches and very flat over the full signal range. 3. Low Power Consumption. The ADG798-KGD operates equally well as either a multiplexer or The power consumption of the ADG798-KGD is specified a demultiplexer and has an input signal range that extends to at <0.01 μW. the supplies. 4. Break-Before-Make Switching Action.
Rev. 0 Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2017 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS METAL MASK DIE IMAGE GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY CONTINUOUS CURRENT PER CHANNEL, Sx OR D PEAK CURRENT PER CHANNEL, Sx OR D (PULSED AT 1 MS, 10% DUTY CYCLE MAXIMUM) ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TRUTH TABLE TEST CIRCUITS OUTLINE DIMENSIONS DIE SPECIFICATIONS AND ASSEMBLY RECOMMENDATIONS ORDERING GUIDE
