Datasheet ADG798-KGD (Analog Devices) - 7
DescriptionHigh Temperature, Low Voltage, 8-Channel Multiplexer
Pages / Page13 / 7 — Known Good Die. ADG798-KGD. ABSOLUTE MAXIMUM RATINGS. Table 6. Parameter …
File Format / SizePDF / 822 Kb
Known Good Die. ADG798-KGD. ABSOLUTE MAXIMUM RATINGS. Table 6. Parameter Rating. ESD CAUTION
Known Good Die ADG798-KGD ABSOLUTE MAXIMUM RATINGS Table 6 Parameter Rating ESD CAUTION
link to page 6 link to page 6
TA = 25°C, unless otherwise noted. Stresses at or above those listed under Absolute Maximum
Table 6.
Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these
Parameter Rating
or any other conditions above those indicated in the operational VDD to VSS 7 V section of this specification is not implied. Operation beyond VDD to GND −0.3 V to +7 V the maximum operating conditions for extended periods may VSS to GND +0.3 V to −3.5 V affect product reliability. Analog Inputs1 VSS − 0.3 V to VDD + 0.3 V or 30 mA, whichever Only one absolute maximum rating can be applied at any one time. occurs first
ESD CAUTION
Digital Inputs1 −0.3 V to VDD + 0.3 V or 30 mA, whichever occurs first Peak Current, Sx or D (Pulsed at 1 ms, See Table 5 10% Duty Cycle Maximum) Continuous Current, Sx or D2 Data + 5% Operating Temperature Range −55°C to +210°C 1 Overvoltages at Ax, EN, Sx, or D are clamped by internal codes. Limit the current to the maximum ratings given. 2 See Table 4. Rev. 0 | Page 7 of 13 Document Outline FEATURES APPLICATIONS METAL MASK DIE IMAGE GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY CONTINUOUS CURRENT PER CHANNEL, Sx OR D PEAK CURRENT PER CHANNEL, Sx OR D (PULSED AT 1 MS, 10% DUTY CYCLE MAXIMUM) ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TRUTH TABLE TEST CIRCUITS OUTLINE DIMENSIONS DIE SPECIFICATIONS AND ASSEMBLY RECOMMENDATIONS ORDERING GUIDE
