Datasheet ADG5248F, ADG5249F (Analog Devices) - 7
DescriptionUser Defined Fault Protection and Detection, 0.8 pC QINJ, 8:1/Dual 4:1 Multiplexers
Pages / Page34 / 7 — Data Sheet. ADG5248F/ADG5249F. −40°C to −40°C to. Parameter. +25°C +85°C. …
RevisionA
File Format / SizePDF / 677 Kb
Data Sheet. ADG5248F/ADG5249F. −40°C to −40°C to. Parameter. +25°C +85°C. +125°C. Unit. Test Conditions/Comments. 12 V SINGLE SUPPLY
Data Sheet ADG5248F/ADG5249F −40°C to −40°C to Parameter +25°C +85°C +125°C Unit Test Conditions/Comments 12 V SINGLE SUPPLY
link to page 23 link to page 21 link to page 23
CD (On), CS (On) VS = 0 V, f = 1 MHz ADG5248F 19 pF typ ADG5249F 14 pF typ POWER REQUIREMENTS VDD = POSFV = +22 V; VSS = NEGFV = −22 V; digital inputs = 0 V, 5 V, or VDD Normal Mode IDD 1.15 mA typ IPOSFV 0.15 mA typ IDD + IPOSFV 2 2 mA max IGND 0.75 mA typ 1.25 1.25 mA max ISS 0.45 mA typ INEGFV 0.2 mA typ ISS + INEGFV 0.8 0.85 mA max Fault Mode VS = ±55 V IDD 1.4 mA typ IPOSFV 0.2 mA typ IDD + IPOSFV 2.2 2.3 mA max IGND 0.9 mA typ 1.6 1.7 mA max ISS 0.45 mA typ INEGFV 0.2 mA typ ISS + INEGFV 1.0 1.1 mA max VDD/VSS ±5 V min GND = 0 V ±22 V max GND = 0 V 1 Guaranteed by design; not subject to production test.
12 V SINGLE SUPPLY
VDD = 12 V ± 10%, VSS = 0 V, GND = 0 V, CDECOUPLING = 0.1 µF, unless otherwise noted.
Table 3. −40°C to −40°C to Parameter +25°C +85°C +125°C Unit Test Conditions/Comments
ANALOG SWITCH VDD = 10.8 V, VSS = 0 V, see Figure 38 Analog Signal Range 0 V to VDD V On Resistance, RON 630 Ω typ VS = 0 V to 10 V, IS = −1 mA 690 710 730 Ω max 270 Ω typ VS = 3.5 V to 8.5 V, IS = −1 mA 290 355 410 Ω max On-Resistance Match Between 6 Ω typ VS = 0 V to 10 V, IS = −1 mA Channels, ∆RON 17 19 19 Ω max 3 Ω typ VS = 3.5 V to 8.5 V, IS = −1 mA 6.5 11 12 Ω max On-Resistance Flatness, RFLAT(ON) 380 Ω typ VS = 0 V to 10 V, IS = −1 mA 440 460 460 Ω max 25 Ω typ VS = 3.5 V to 8.5 V, IS = −1 mA 27 28 28 Ω max Threshold Voltage, VT 0.7 V typ See Figure 30 LEAKAGE CURRENTS VDD = 13.2 V, VSS = 0 V Source Off Leakage, IS (Off) ±0.1 nA typ VS = 1 V/10 V, VD = 10 V/1 V, see Figure 36 ±1 ±2 ±5 nA max Rev. A | Page 7 of 34 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY ±20 V DUAL SUPPLY 12 V SINGLE SUPPLY 36 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, Sx, D, OR Dx ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY THEORY OF OPERATION SWITCH ARCHITECTURE ESD Performance Trench Isolation USER DEFINED FAULT PROTECTION Power-On Protection Power-Off Protection Digital Input Protection Overvoltage Interrupt Flag APPLICATIONS INFORMATION POWER SUPPLY RAILS POWER SUPPLY SEQUENCING PROTECTION SIGNAL RANGE POWER SUPPLY RECOMMENDATIONS HIGH VOLTAGE SURGE SUPPRESSION INTELLIGENT FAULT DETECTION LARGE VOLTAGE, HIGH FREQUENCY SIGNALS OUTLINE DIMENSIONS ORDERING GUIDE
