Datasheet ADG5412F, ADG5413F (Analog Devices)
Description | Fault Protection and Detection, 10 Ω RON, Quad SPST Switches |
Pages / Page | 28 / 1 — Fault Protection and Detection,. 10 Ω R. ON, Quad SPST Switches. Data … |
Revision | C |
File Format / Size | PDF / 647 Kb |
Fault Protection and Detection,. 10 Ω R. ON, Quad SPST Switches. Data Sheet. ADG5412F/. ADG5413F. FEATURES. FUNCTIONAL BLOCK DIAGRAMS
Fault Protection and Detection, 10 Ω R ON, Quad SPST Switches Data Sheet ADG5412F/ ADG5413F FEATURES FUNCTIONAL BLOCK DIAGRAMS Overvoltage protection up to −55 V and +55 V ADG5412F Power-off protection up to −55 V and +55 V S1 D1 Overvoltage detection on source pins S2 D2 Low on resistance: 10 Ω S3 D3 On-resistance flatness of 0.5 Ω S4 D4 5.5 kV human body model (HBM) ESD rating Latch-up immune under any circumstance FAULT Known state without digital inputs present DETECTION FF + SWITCH V DRIVER SS to VDD analog signal range ±5 V to ±22 V dual supply operation IN1 IN2 IN3 IN4 8 V to 44 V single-supply operation
001
NOTES Fully specified at ±15 V, ±20 V, +12 V, and +36 V 1. SWITCHES SHOWN FOR A LOGIC 1 INPUT.
12472-
Figure 1. ADG5412F
Analog input/output modules ADG5413F Process control/distributed control systems S1 D1 Data acquisition S2 D2 Instrumentation S3 D3 Avionics S4 D4 Automatic test equipment Communication systems FAULT DETECTION Relay replacement FF + SWITCH DRIVER IN1 IN2 IN3 IN4
200
NOTES 1. SWITCHES SHOWN FOR A LOGIC 1 INPUT.
12472- Figure 2. ADG5413F
GENERAL DESCRIPTION
The ADG5412F and ADG5413F contain four independently The low on resistance of these switches, combined with controlled single-pole/single-throw (SPST) switches. The on-resistance flatness over a significant portion of the signal ADG5412F has four switches that turn on with Logic 1 inputs. range make them an ideal solution for data acquisition and gain The ADG5413F has two switches that turn on and two switches switching applications where excellent linearity and low that turn off with Logic 1 inputs. Each switch conducts equally distortion are critical. wel in both directions when on, and each switch has an input
PRODUCT HIGHLIGHTS
signal range that extends to the supplies. The digital inputs are compatible with 3 V logic inputs over the full operating supply 1. Source pins are protected against voltages greater than the range. supply rails, up to −55 V and +55 V. 2. Source pins are protected against voltages between −55 V When no power supplies are present, the switch remains in the off and +55 V in an unpowered state. condition, and the switch inputs are high impedance. Under 3. Overvoltage detection with digital output indicates normal operating conditions, if the analog input signal levels on operating state of switches. any Sx pin exceed VDD or VSS by a threshold voltage, VT, the 4. Trench isolation guards against latch-up. switch turns off. Input signal levels up to +55 V or −55 V relative to 5. Optimized for low on resistance and on-resistance flatness. ground are blocked, in both the powered and unpowered 6. The ADG5412F/ADG5413F can be operated from a dual condition. supply of ±5 V up to ±22 V or a single power supply of 8 V up to 44 V.
Rev. C Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2014–2017 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY ±20 V DUAL SUPPLY 12 V SINGLE SUPPLY 36 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, Sx OR Dx ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY THEORY OF OPERATION SWITCH ARCHITECTURE ESD Performance Trench Isolation FAULT PROTECTION Power-On Protection Power-Off Protection Digital Input Protection Overvoltage Interrupt Flag APPLICATIONS INFORMATION POWER SUPPLY RAILS POWER SUPPLY SEQUENCING PROTECTION SIGNAL RANGE LOW IMPEDANCE CHANNEL PROTECTION HIGH VOLTAGE SURGE SUPPRESSION INTELLIGENT FAULT DETECTION LARGE VOLTAGE, HIGH FREQUENCY SIGNALS OUTLINE DIMENSIONS ORDERING GUIDE
