Datasheet ADG5401 (Analog Devices) - 3
DescriptionHigh Voltage Latch-Up Proof, Single SPST Switch
Pages / Page17 / 3 — Data Sheet. ADG5401. SPECIFICATIONS ±15 V DUAL SUPPLY. Table 1. …
RevisionA
File Format / SizePDF / 377 Kb
Data Sheet. ADG5401. SPECIFICATIONS ±15 V DUAL SUPPLY. Table 1. Parameter. 25°C. −40°C to +85°C. −40°C to +125°C. Unit
Data Sheet ADG5401 SPECIFICATIONS ±15 V DUAL SUPPLY Table 1 Parameter 25°C −40°C to +85°C −40°C to +125°C Unit
link to page 13 link to page 13 link to page 13 link to page 13 link to page 13 link to page 13 link to page 14 link to page 13 link to page 13 link to page 13 link to page 13
VDD = +15 V ± 10%, VSS = −15 V ± 10%, GND = 0 V, unless otherwise noted.
Table 1. Parameter 25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range VDD to VSS V On Resistance, RON 6.5 Ω typ VS = ±10 V, IS = −10 mA; see Figure 21 8 10 12 Ω max VDD = +13.5 V, VSS = −13.5 V On-Resistance Flatness, RFLAT (ON) 1 Ω typ VS = ±10 V, IS = −10 mA 1.4 1.7 2 Ω max LEAKAGE CURRENTS VDD = +16.5 V, VSS = −16.5 V Source Off Leakage, IS (Off) ±0.1 nA typ VS = ±10 V, VD =  10 V; see Figure 20 ±0.5 ±2 ±20 nA max Drain Off Leakage, ID (Off) ±0.1 nA typ VS = ±10 V, VD =  10 V; see Figure 20 ±0.5 ±2 ±20 nA max Channel On Leakage, ID (On), IS (On) ±0.2 nA typ VS = VD = ±10 V; see Figure 23 ±1 ±8 ±40 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH 0.002 µA typ VIN = VGND or VDD ±0.1 µA max Digital Input Capacitance, CIN 6 pF typ DYNAMIC CHARACTERISTICS1 tON 160 ns typ RL = 300 Ω, CL = 35 pF 193 230 253 ns max VS = 10 V; see Figure 26 tOFF 175 ns typ RL = 300 Ω, CL = 35 pF 207 230 242 ns max VS = 10 V; see Figure 26 Charge Injection, QINJ 220 pC typ VS = 0 V, RS = 0 Ω, CL = 1 nF; see Figure 27 Off Isolation −50 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 22 Total Harmonic Distortion + Noise 0.01 % typ RL = 1 kΩ, 15 V p-p, f = 20 Hz to (THD + N) 20 kHz; see Figure 24 −3 dB Bandwidth 170 MHz typ RL = 50 Ω, CL = 5 pF; see Figure 25 Insertion Loss −0.4 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 25 CS (Off) 22 pF typ VS = 0 V, f = 1 MHz CD (Off) 24 pF typ VS = 0 V, f = 1 MHz CD (On), CS (On) 75 pF typ VS = 0 V, f = 1 MHz POWER REQUIREMENTS VDD = +16.5 V, VSS = −16.5 V IDD 45 µA typ Digital inputs = 0 V or VDD 55 70 µA max ISS 0.001 µA typ Digital inputs = 0 V or VDD 1 µA max VDD/VSS ±9/±22 V min/V max GND = 0 V 1 Guaranteed by design; not subject to production test. Rev. A | Page 3 of 17 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY ±20 V DUAL SUPPLY 12 V SINGLE SUPPLY 36 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, S OR D ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY APPLICATIONS INFORMATION TRENCH ISOLATION OUTLINE DIMENSIONS ORDERING GUIDE
