Datasheet ADG5401 (Analog Devices) - 5
DescriptionHigh Voltage Latch-Up Proof, Single SPST Switch
Pages / Page17 / 5 — Data Sheet. ADG5401. 12 V SINGLE SUPPLY. Table 3. Parameter. 25°C. −40°C …
RevisionA
File Format / SizePDF / 377 Kb
Data Sheet. ADG5401. 12 V SINGLE SUPPLY. Table 3. Parameter. 25°C. −40°C to +85°C. −40°C to +125°C. Unit. Test Conditions/Comments
Data Sheet ADG5401 12 V SINGLE SUPPLY Table 3 Parameter 25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments
link to page 13 link to page 13 link to page 13 link to page 13 link to page 13 link to page 13 link to page 14 link to page 13 link to page 13 link to page 13 link to page 13
VDD = 12 V ± 10%, VSS = 0 V, GND = 0 V, unless otherwise noted.
Table 3. Parameter 25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 V to VDD V On Resistance, RON 14 Ω typ VS = 0 V to 10 V, IS = −10 mA; see Figure 21 16 19 22 Ω max VDD = 10.8 V, VSS = 0 V On-Resistance Flatness, RFLAT (ON) 2.8 Ω typ VS = 0 V to 10 V, IS = −10 mA 4 5.5 7 Ω max LEAKAGE CURRENTS VDD = +13.2 V, VSS = 0 V Source Off Leakage, IS (Off) ±0.1 nA typ VS = 1 V to 10 V, VD = 10 V to 1 V; see Figure 20 ±0.5 ±2 ±20 nA max Drain Off Leakage, ID (Off) ±0.1 nA typ VS = 1 V to 10 V, VD = 10 V to 1 V; see Figure 20 ±0.5 ±2 ±20 nA max Channel On Leakage, ID (On), IS (On) ±0.2 nA typ VS = VD = 1 V to 10 V; see Figure 23 ±1 ±8 ±40 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH 0.002 µA typ VIN = VGND or VDD ±0.1 µA max Digital Input Capacitance, CIN 6 pF typ DYNAMIC CHARACTERISTICS1 tON 260 ns typ RL = 300 Ω, CL = 35 pF 327 406 454 ns max VS = 8 V; see Figure 26 tOFF 200 ns typ RL = 300 Ω, CL = 35 pF 244 280 300 ns max VS = 8 V; see Figure 26 Charge Injection, QINJ 95 pC typ VS = 6 V, RS = 0 Ω, CL = 1 nF; see Figure 27 Off Isolation −50 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 22 Total Harmonic Distortion + Noise 0.02 % typ RL = 1 kΩ, 6 V p-p, f = 20 Hz to (THD + N) 20 kHz; see Figure 24 −3 dB Bandwidth 190 MHz typ RL = 50 Ω, CL = 5 pF; see Figure 25 Insertion Loss −0.9 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 25 CS (Off) 28 pF typ VS = 6 V, f = 1 MHz CD (Off) 30 pF typ VS = 6 V, f = 1 MHz CD (On), CS (On) 60 pF typ VS = 6 V, f = 1 MHz POWER REQUIREMENTS VDD = 13.2 V IDD 40 µA typ Digital inputs = 0 V or VDD 50 65 µA max VDD 9/40 V min/V max GND = 0 V, VSS = 0 V 1 Guaranteed by design; not subject to production test. Rev. A | Page 5 of 17 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY ±20 V DUAL SUPPLY 12 V SINGLE SUPPLY 36 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, S OR D ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY APPLICATIONS INFORMATION TRENCH ISOLATION OUTLINE DIMENSIONS ORDERING GUIDE
