Datasheet ADG5421, ADG5423 (Analog Devices) - 8
DescriptionHigh Voltage Latch-Up Proof, Dual SPST Switches
Pages / Page17 / 8 — ADG5421/ADG5423. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 6. Parameter …
File Format / SizePDF / 402 Kb
ADG5421/ADG5423. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 6. Parameter Rating. ESD CAUTION
ADG5421/ADG5423 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 6 Parameter Rating ESD CAUTION
link to page 7
Table 6.
Stresses at or above those listed under Absolute Maximum
Parameter Rating
Ratings may cause permanent damage to the product. This is a V stress rating only; functional operation of the product at these DD to VSS 48 V V or any other conditions above those indicated in the operational DD to GND −0.3 V to +48 V V section of this specification is not implied. Operation beyond SS to GND +0.3 V to −48 V Analog Inputs1 V the maximum operating conditions for extended periods may SS − 0.3 V to VDD + 0.3 V or 30 mA, whichever occurs first affect product reliability. Digital Inputs1 VSS − 0.3 V to VDD + 0.3 V or Only one absolute maximum rating can be applied at any 30 mA, whichever occurs first one time. Peak Current, Sx or Dx Pins 300 mA (pulsed at 1 ms, 10% duty cycle maximum)
ESD CAUTION
Continuous Current, Sx or Dx2 Data + 15% Temperature Range Operating −40°C to +125°C Storage −65°C to +150°C Junction Temperature 150°C Thermal Impedance, θ JA 10-Lead MSOP (4-Layer Board) 133.1°C/W 10-Lead LFCSP 48.7°C/W Reflow Soldering Peak As per JEDEC J-STD-020 Temperature, Pb Free Human Body Model (HBM) ESD 8 kV 1 Overvoltages at the INx, Sx, and Dx pins are clamped by internal diodes. Limit current to the maximum ratings given. 2 See Table 5. Rev. A | Page 8 of 17 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY ±20 V DUAL SUPPLY 12 V SINGLE SUPPLY 36 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, Sx OR Dx ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY APPLICATIONS INFORMATION TRENCH ISOLATION OUTLINE DIMENSIONS ORDERING GUIDE
