Datasheet ADG5421, ADG5423 (Analog Devices) - 9
DescriptionHigh Voltage Latch-Up Proof, Dual SPST Switches
Pages / Page17 / 9 — Data Sheet. ADG5421/ADG5423. PIN CONFIGURATIONS AND FUNCTION …
RevisionA
File Format / SizePDF / 402 Kb
Data Sheet. ADG5421/ADG5423. PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS. S1 1. 10 D1. S2 2. 9 D2. ADG5421/. NC 3. 8 VSS. ADG5423. GND 4
Data Sheet ADG5421/ADG5423 PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS S1 1 10 D1 S2 2 9 D2 ADG5421/ NC 3 8 VSS ADG5423 GND 4
Data Sheet ADG5421/ADG5423 PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS S1 1 10 D1 S1 1 10 D1 S2 2 9 D2 ADG5421/ S2 2 9 D2 ADG5421/ NC 3 8 VSS ADG5423 NC 3 ADG5423 8 VSS GND 4 7 IN1 TOP VIEW TOP VIEW GND 4 (Not to Scale) 7 IN1 VDD 5 (Not to Scale) 6 IN2 V 5 DD 6 IN2
003
NOTES 1. NC = NO CONNECT. NOT INTERNALLY CONNECTED.
11369-
NOTES 1. NC = NO CONNECT. DO NOT CONNECT TO THIS PIN.
03369- Figure 3. MSOP Pin Configuration
2. EXPOSED PAD TIED TO SUBSTRATE, VSS.
113 Figure 4. LFCSP Pin Configuration
Table 7. Pin Function Descriptions MSOP Pin No.1 LFCSP Pin No. Mnemonic Description
1 1 S1 Source Terminal 1. This pin can be an input or output. 2 2 S2 Source Terminal 2. This pin can be an input or output. 3 3 NC No Connect. Not internally connected. 4 4 GND Ground (0 V) Reference. 5 5 VDD Most Positive Power Supply Potential. 6 6 IN2 Logic Control Input. 7 7 IN1 Logic Control Input. 8 8 VSS Most Negative Power Supply Potential. 9 9 D2 Drain Terminal 2. This pin can be an input or output. 10 10 D1 Drain Terminal 1. This pin can be an input or output. N/A EPAD Exposed Pad. The exposed pad is tied to substrate, VSS. 1 N/A means not applicable.
Table 8. ADG5421 Truth Table INx Switch Conditions
0 Off 1 On
Table 9. ADG5423 Truth Table INx Switch 1 Condition Switch 2 Condition
0 Off On 1 On Off Rev. A | Page 9 of 17 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY ±20 V DUAL SUPPLY 12 V SINGLE SUPPLY 36 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, Sx OR Dx ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY APPLICATIONS INFORMATION TRENCH ISOLATION OUTLINE DIMENSIONS ORDERING GUIDE
