Datasheet The ADG5206, ADG5207 (Analog Devices) - 3
DescriptionHigh Voltage, Latch-Up Proof, 8-/16-Channel Multiplexers
Pages / Page28 / 3 — Data Sheet. ADG5206/ADG5207. SPECIFICATIONS ±15 V DUAL SUPPLY. Table 1. …
File Format / SizePDF / 430 Kb
Data Sheet. ADG5206/ADG5207. SPECIFICATIONS ±15 V DUAL SUPPLY. Table 1. −40°C to. Parameter. 25°C. +60°C. +85°C. +125°C. Unit
Data Sheet ADG5206/ADG5207 SPECIFICATIONS ±15 V DUAL SUPPLY Table 1 −40°C to Parameter 25°C +60°C +85°C +125°C Unit
link to page 21 link to page 21 link to page 21 link to page 21 link to page 21 link to page 21 link to page 21 link to page 22 link to page 4 link to page 4 link to page 4
VDD = +15 V ± 10%, VSS = −15 V ± 10%, GND = 0 V, unless otherwise noted.
Table 1. −40°C to −40°C to −40°C to Parameter 25°C +60°C +85°C +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range VDD to VSS V On Resistance, RON 155 Ω typ VS = ±10 V, IS = −1 mA; see Figure 32 200 225 250 285 Ω max VDD = +13.5 V, VSS = −13.5 V On Resistance Match Between Channels, 4 Ω typ VS = ±10 V, IS = −1 mA ΔRON 12 13 14 15 Ω max On Resistance Flatness, RFLAT (ON) 48 Ω typ VS = ±10 V, IS = −1 mA 65 73 80 90 Ω max LEAKAGE CURRENTS VDD = +16.5 V, VSS = −16.5 V Source Off Leakage, IS (Off) ±0.005 nA typ VS = ±10 V, VD =  10 V; see Figure 33 ±0.1 ±0.15 ±0.2 ±0.4 nA max Match Between Channels, ΔLeakage, 0.01 0.015 nA typ VS = ±10 V, VD =  10 V IS (Off)1 Drain Off Leakage, ID (Off) VS = ±10 V, VD =  10 V; see Figure 33 ADG5206 ±0.02 nA typ ±0.1 ±0.25 ±0.6 ±3.3 nA max ADG5207 ±0.02 nA typ ±0.1 ±0.25 ±0.4 ±1.7 nA max Match Between Channels, ΔLeakage, 0.015 0.015 nA typ VS = ±10 V, VD =  10 V ID (Off), ADG5207 Only Channel On Leakage, ID (On), IS (On) VS = VD = ±10 V; see Figure 34 ADG5206 ±0.02 nA typ ±0.1 ±0.25 ±0.6 ±3.3 nA max ADG5207 ±0.02 nA typ ±0.1 ±0.2 ±0.4 ±1.7 nA max Match Between Channels, ΔLeakage, 0.01 0.03 nA typ VS = VD = ±10 V ID (On), IS (On)2 DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH 0.002 µA typ VIN = VGND or VDD ±0.1 µA max Digital Input Capacitance, CIN 3 pF typ DYNAMIC CHARACTERISTICS3 Transition Time, tTRANSITION 200 ns typ RL = 300 Ω, CL = 35 pF 260 300 320 360 ns max VS = 10 V; see Figure 35 tON (EN) 180 ns typ RL = 300 Ω, CL = 35 pF 245 260 270 285 ns max VS = 10 V; see Figure 36 tOFF (EN) 140 ns typ RL = 300 Ω, CL = 35 pF 200 220 240 270 ns max VS = 10 V; see Figure 36 Break-Before-Make Time Delay, tD 85 ns typ RL = 300 Ω, CL = 35 pF 27 ns min VS1 = VS2 = 10 V; see Figure 37 Rev. A | Page 3 of 28 Document Outline Features Applications Functional Block Diagrams General Description Product Highlights Revision History Specifications ±15 V Dual Supply ±20 V Dual Supply 12 V Single Supply 36 V Single Supply Continuous Current per Channel, Sx, D, or Dx Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Test Circuits Terminology Applications Information Trench Isolation Outline Dimensions Ordering Guide
