Datasheet The ADG5206, ADG5207 (Analog Devices) - 5
DescriptionHigh Voltage, Latch-Up Proof, 8-/16-Channel Multiplexers
Pages / Page28 / 5 — Data Sheet. ADG5206/ADG5207. −40°C to. Parameter. 25°C. +60°C. +85°C. …
File Format / SizePDF / 430 Kb
Data Sheet. ADG5206/ADG5207. −40°C to. Parameter. 25°C. +60°C. +85°C. +125°C. Unit. Test Conditions/Comments
Data Sheet ADG5206/ADG5207 −40°C to Parameter 25°C +60°C +85°C +125°C Unit Test Conditions/Comments
link to page 21 link to page 21 link to page 21 link to page 21 link to page 21 link to page 21 link to page 22 link to page 22 link to page 22 link to page 22 link to page 22 link to page 22 link to page 6 link to page 6 link to page 6
Data Sheet ADG5206/ADG5207 −40°C to −40°C to −40°C to Parameter 25°C +60°C +85°C +125°C Unit Test Conditions/Comments
LEAKAGE CURRENTS VDD = +22 V, VSS = −22 V Source Off Leakage, IS (Off) ±0.005 nA typ VS = ±15 V, VD =  15 V; see Figure 33 ±0.1 ±0.15 ±0.2 ±0.4 nA max Match Between Channels, ΔLeakage, IS (Off)1 0.01 0.015 nA typ Drain Off Leakage, ID (Off) VS = ±15 V, VD =  15 V; see Figure 33 ADG5206 ±0.02 nA typ ±0.1 ±0.25 ±0.6 ±3.3 nA max ADG5207 ±0.02 nA typ ±0.1 ±0.25 ±0.4 ±1.7 nA max Match Between Channels, ΔLeakage, 0.015 0.015 nA typ ID (Off), ADG5207 Only Channel On Leakage, ID (On), IS (On) VS = VD = ±15 V; see Figure 34 ADG5206 ±0.02 nA typ ±0.1 ±0.25 ±0.6 ±3.3 nA max ADG5207 ±0.02 nA typ ±0.1 ±0.2 ±0.4 ±1.7 nA max Match Between Channels, ΔLeakage, 0.01 0.03 nA typ ID (On), IS (On)2 DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH ±0.002 µA typ VIN = VGND or VDD ±0.1 µA max Digital Input Capacitance, CIN 3 pF typ DYNAMIC CHARACTERISTICS3 Transition Time, tTRANSITION 185 ns typ RL = 300 Ω, CL = 35 pF 240 270 290 320 ns max VS = 10 V; see Figure 35 tON (EN) 175 ns typ RL = 300 Ω, CL = 35 pF 230 245 255 270 ns max VS = 10 V; see Figure 36 tOFF (EN) 135 ns typ RL = 300 Ω, CL = 35 pF 185 205 220 245 ns max VS = 10 V; see Figure 36 Break-Before-Make Time Delay, tD 75 ns typ RL = 300 Ω, CL = 35 pF 27 ns min VS1 = VS2 = 10 V; see Figure 37 Charge Injection, QINJ 0.45 pC typ VS = 0 V, RS = 0 Ω, CL = 1 nF; see Figure 38 ±4 ±4 pC typ VS = ±10 V, RS = 0 Ω, CL = 1 nF Off Isolation −90 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 39 Channel-to-Channel Crosstalk −76 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 40 −3 dB Bandwidth RL = 50 Ω, CL = 5 pF; see Figure 41 ADG5206 65 MHz typ ADG5207 145 MHz typ Insertion Loss 5.6 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 41 CS (Off) 3.3 pF typ VS = 0 V, f = 1 MHz Rev. A | Page 5 of 28 Document Outline Features Applications Functional Block Diagrams General Description Product Highlights Revision History Specifications ±15 V Dual Supply ±20 V Dual Supply 12 V Single Supply 36 V Single Supply Continuous Current per Channel, Sx, D, or Dx Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Test Circuits Terminology Applications Information Trench Isolation Outline Dimensions Ordering Guide
