Datasheet The ADG5206, ADG5207 (Analog Devices) - 6
DescriptionHigh Voltage, Latch-Up Proof, 8-/16-Channel Multiplexers
Pages / Page28 / 6 — ADG5206/ADG5207. Data Sheet. −40°C to. Parameter. 25°C. +60°C. +85°C. …
File Format / SizePDF / 430 Kb
ADG5206/ADG5207. Data Sheet. −40°C to. Parameter. 25°C. +60°C. +85°C. +125°C. Unit. Test Conditions/Comments. 12 V SINGLE SUPPLY. Table 3
ADG5206/ADG5207 Data Sheet −40°C to Parameter 25°C +60°C +85°C +125°C Unit Test Conditions/Comments 12 V SINGLE SUPPLY Table 3
link to page 21 link to page 21 link to page 21 link to page 21 link to page 7 link to page 7
ADG5206/ADG5207 Data Sheet −40°C to −40°C to −40°C to Parameter 25°C +60°C +85°C +125°C Unit Test Conditions/Comments
CD (Off) ADG5206 62 pF typ VS = 0 V, f = 1 MHz ADG5207 32 pF typ VS = 0 V, f = 1 MHz CD (On), CS (On) ADG5206 67 pF typ VS = 0 V, f = 1 MHz ADG5207 35 pF typ VS = 0 V, f = 1 MHz POWER REQUIREMENTS VDD = +22 V, VSS = −22 V IDD 50 µA typ Digital inputs = 0 V or VDD 70 110 µA max ISS 0.001 µA typ Digital inputs = 0 V or VDD 1 µA max VDD/VSS ±9/±22 V min/V max GND = 0 V 1 The off channel leakage delta is calculated using the maximum of VS = +15 V and VD = −15 V, or VS = −15 V and VD = +15 V. 2 The on channel leakage delta is calculated using the maximum of VS = VD = +15 V, or VS = VD = −15 V. 3 Guaranteed by design; not subject to production test.
12 V SINGLE SUPPLY
VDD = 12 V ± 10%, VSS = 0 V, GND = 0 V, unless otherwise noted.
Table 3. −40°C to −40°C to −40°C to Parameter 25°C +60°C +85°C +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 V to VDD V On Resistance, RON 350 Ω typ VS = 0 V to 10 V, IS = −1 mA; see Figure 32 500 560 610 700 Ω max VDD = 10.8 V, VSS = 0 V On-Resistance Match Between 5 Ω typ VS = 0 V to 10 V, IS = −1 mA Channels, ∆RON 20 21 22 24 Ω max On-Resistance Flatness, RFLAT (ON) 170 Ω typ VS = 0 V to 10 V, IS = −1 mA 280 310 335 370 Ω max LEAKAGE CURRENTS VDD = +13.2 V, VSS = 0 V Source Off Leakage, IS (Off) ±0.005 nA typ VS = 1 V/10 V, VD = 10 V/1 V; see Figure 33 ±0.1 ±0.15 ±0.2 ±0.4 nA max Match Between Channels, ΔLeakage, 0.01 0.015 nA typ IS (Off)1 Drain Off Leakage, ID (Off) VS = 1 V/10 V, VD = 1 V/10 V; see Figure 33 ADG5206 ±0.02 nA typ ±0.1 ±0.25 ±0.6 ±3.3 nA max ADG5207 ±0.02 nA typ ±0.1 ±0.25 ±0.4 ±1.7 nA max Match Between Channels, ΔLeakage, 0.015 0.015 nA typ ID (Off), ADG5207 Only Channel On Leakage, ID (On), IS (On) VS = VD = 1 V/10 V; see Figure 34 ADG5206 ±0.02 nA typ ±0.1 ±0.25 ±0.6 ±3.3 nA max ADG5207 ±0.02 nA typ ±0.1 ±0.2 ±0.4 ±1.7 nA max Match Between Channels, ΔLeakage, 0.01 0.03 nA typ ID (On), IS (On)2 Rev. A | Page 6 of 28 Document Outline Features Applications Functional Block Diagrams General Description Product Highlights Revision History Specifications ±15 V Dual Supply ±20 V Dual Supply 12 V Single Supply 36 V Single Supply Continuous Current per Channel, Sx, D, or Dx Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Test Circuits Terminology Applications Information Trench Isolation Outline Dimensions Ordering Guide
