Datasheet The ADG5206, ADG5207 (Analog Devices) - 7
DescriptionHigh Voltage, Latch-Up Proof, 8-/16-Channel Multiplexers
Pages / Page28 / 7 — Data Sheet. ADG5206/ADG5207. −40°C to. Parameter. 25°C. +60°C. +85°C. …
RevisionA
File Format / SizePDF / 430 Kb
Data Sheet. ADG5206/ADG5207. −40°C to. Parameter. 25°C. +60°C. +85°C. +125°C. Unit. Test Conditions/Comments
Data Sheet ADG5206/ADG5207 −40°C to Parameter 25°C +60°C +85°C +125°C Unit Test Conditions/Comments
link to page 21 link to page 21 link to page 21 link to page 22 link to page 22 link to page 22 link to page 22 link to page 22 link to page 22 link to page 7
Data Sheet ADG5206/ADG5207 −40°C to −40°C to −40°C to Parameter 25°C +60°C +85°C +125°C Unit Test Conditions/Comments
DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH 0.002 µA typ VIN = VGND or VDD ±0.1 µA max Digital Input Capacitance, CIN 3 pF typ DYNAMIC CHARACTERISTICS3 Transition Time, tTRANSITION 290 ns typ RL = 300 Ω, CL = 35 pF 290 440 480 550 ns max VS = 8 V; see Figure 35 tON (EN) 230 ns typ RL = 300 Ω, CL = 35 pF 290 320 340 370 ns max VS = 8 V; see Figure 36 tOFF (EN) 230 ns typ RL = 300 Ω, CL = 35 pF 315 360 390 450 ns max VS = 8 V; see Figure 36 Break-Before-Make Time Delay, tD 170 ns typ RL = 300 Ω, CL = 35 pF 45 ns min VS1 = VS2 = 8 V; see Figure 37 Charge Injection, QINJ 0.25 pC typ VS = 6 V, RS = 0 Ω, CL = 1 nF; see Figure 38 ±0.6 ±0.7 pC typ VS = 0 V to 10 V, RS = 0 Ω, CL = 1 nF Off Isolation −90 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 39 Channel-to-Channel Crosstalk −76 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 40 −3 dB Bandwidth RL = 50 Ω, CL = 5 pF; see Figure 41 ADG5206 50 MHz typ ADG5207 105 MHz typ Insertion Loss 8.55 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 41 CS (Off) 3.6 pF typ VS = 6 V, f = 1 MHz CD (Off) ADG5206 71 pF typ VS = 6 V, f = 1 MHz ADG5207 36 pF typ VS = 6 V, f = 1 MHz CD (On), CS (On) ADG5206 75 pF typ VS = 6 V, f = 1 MHz ADG5207 40 pF typ VS = 6 V, f = 1 MHz POWER REQUIREMENTS VDD = 13.2 V IDD 40 µA typ Digital inputs = 0 V or VDD 50 65 µA max VDD 9/40 V min/V max GND = 0 V, VSS = 0 V 1 The off channel leakage delta is calculated using the maximum of VS = 1 V and VD = 10 V, or VS = 10 V and VD = 1 V. 2 The on channel leakage delta is calculated using the maximum of VS = VD = 1 V, or VS = VD = 10 V. 3 Guaranteed by design; not subject to production test. Rev. A | Page 7 of 28 Document Outline Features Applications Functional Block Diagrams General Description Product Highlights Revision History Specifications ±15 V Dual Supply ±20 V Dual Supply 12 V Single Supply 36 V Single Supply Continuous Current per Channel, Sx, D, or Dx Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Test Circuits Terminology Applications Information Trench Isolation Outline Dimensions Ordering Guide
