Datasheet ADG5204 (Analog Devices) - 8
DescriptionHigh Voltage, Latch-up Proof, 4-Channel Multiplexer
Pages / Page20 / 8 — ADG5204. ABSOLUTE MAXIMUM RATINGS. Table 6. Parameter Rating. ESD CAUTION
File Format / SizePDF / 314 Kb
ADG5204 ABSOLUTE MAXIMUM RATINGS Table 6 Parameter Rating ESD CAUTION
link to page 8 link to page 8 link to page 8 link to page 7
Table 6.
Stresses above those listed under Absolute Maximum Ratings
Parameter Rating
may cause permanent damage to the device. This is a stress V rating only; functional operation of the device at these or any DD to VSS 48 V V other conditions above those indicated in the operational DD to GND −0.3 V to +48 V V section of this specification is not implied. Exposure to absolute SS to GND +0.3 V to −48 V Analog Inputs1 V maximum rating conditions for extended periods may affect SS − 0.3 V to VDD + 0.3 V or 30 mA, whichever occurs first device reliability. Digital Inputs1 VSS − 0.3 V to VDD + 0.3 V or Only one absolute maximum rating can be applied at any 30 mA, whichever occurs first one time. Peak Current, Sx or D Pins 81 mA (pulsed at 1 ms, 10% duty cycle maximum)
ESD CAUTION
Continuous Current, Sx or D2 Data + 15% Operating Temperature Range −40°C to +125°C Storage Temperature Range −65°C to +150°C Junction Temperature 150°C Thermal Impedance, θ JA 16-Lead TSSOP, θ JA Thermal 112.6°C/W Impedance (4-Layer Board) 16-Lead LFCSP, θJA Thermal 30.4°C/W Impedance (4-Layer Board) Reflow Soldering Peak 260(+0/−5)°C Temperature, Pb Free 1 Overvoltages at the Sx and D pins are clamped by internal diodes. Limit current to the maximum ratings given. 2 See Table 5. Rev. A | Page 8 of 20 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY ±20 V DUAL SUPPLY 12 V SINGLE SUPPLY 36 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, Sx OR D ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TRUTH TABLE TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY TRENCH ISOLATION APPLICATIONS INFORMATION OUTLINE DIMENSIONS ORDERING GUIDE
