Datasheet ADG5204 (Analog Devices) - 9
DescriptionHigh Voltage, Latch-up Proof, 4-Channel Multiplexer
Pages / Page20 / 9 — ADG5204. PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS. A0 1. 14 A1. EN 2. …
RevisionA
File Format / SizePDF / 314 Kb
ADG5204. PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS. A0 1. 14 A1. EN 2. 13 GND. ADG5204 12 VDD. 12 GND. S1 4. TOP VIEW. NC 2. 11 VDD
ADG5204 PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS A0 1 14 A1 EN 2 13 GND ADG5204 12 VDD 12 GND S1 4 TOP VIEW NC 2 11 VDD
link to page 9 link to page 9 link to page 9
ADG5204 PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS N 0 1 C E A A N A0 1 14 A1 6 5 4 3 1 1 1 1 EN 2 13 GND V 3 SS ADG5204 12 VDD V 1 SS 12 GND S1 4 11 TOP VIEW S3 NC 2 ADG5204 11 VDD (Not to Scale) S2 5 10 S4 S1 3 TOP VIEW 10 S3 (Not to Scale) D 6 9 NC S2 4 9 S4 NC 7 8 NC
02
5 6 7 8
0 8-
NC = NO CONNECT
76
C D C C
09
N N N NOTES
03
1. NC = NO CONNECT.
0 8-
2. EXPOSED PAD TIED TO SUBSTRATE, VSS.
76 09 Figure 2. TSSOP Pin Configuration Figure 3. LFCSP Pin Configuration
Table 7. Pin Function Descriptions Pin No. TSSOP LFCSP Mnemonic Description
1 15 A0 Logic Control Input. 2 16 EN Active High Digital Input. When this pin is low, the device is disabled and all switches are off. When this pin is high, the Ax logic inputs determine the on switches. 3 1 VSS Most Negative Power Supply Potential. 4 3 S1 Source Terminal. Can be an input or an output. 5 4 S2 Source Terminal. Can be an input or an output. 6 6 D Drain Terminal. Can be an input or an output. 7 to 9 2, 5, 7, 8, 13 NC No Connect. These pins are open. 10 9 S4 Source Terminal. Can be an input or an output. 11 10 S3 Source Terminal. Can be an input or an output. 12 11 VDD Most Positive Power Supply Potential. 13 12 GND Ground (0 V) Reference. 14 14 A1 Logic Control Input. N/A1 EP Exposed Pad Exposed Pad. The exposed pad is connected internally. For increased reliability of the solder joints and maximum thermal capability, it is recommended that the pad be soldered to the substrate, VSS. 1 N/A means not applicable.
TRUTH TABLE Table 8. EN A1 A0 S1 S2 S3 S4
0 X1 X1 Off Off Off Off 1 0 0 On Off Off Off 1 0 1 Off On Off Off 1 1 0 Off Off On Off 1 1 1 Off Off Off On 1 X is don’t care. Rev. A | Page 9 of 20 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY ±20 V DUAL SUPPLY 12 V SINGLE SUPPLY 36 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, Sx OR D ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TRUTH TABLE TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY TRENCH ISOLATION APPLICATIONS INFORMATION OUTLINE DIMENSIONS ORDERING GUIDE
