Datasheet ADG5208, ADG5209 (Analog Devices) - 9
DescriptionHigh Voltage Latch-Up Proof, 4-/8-Channel Multiplexers
Pages / Page24 / 9 — Data Sheet. ADG5208/ADG5209. ABSOLUTE MAXIMUM RATINGS. Table 7. …
RevisionC
File Format / SizePDF / 472 Kb
Data Sheet. ADG5208/ADG5209. ABSOLUTE MAXIMUM RATINGS. Table 7. Parameter. Rating. ESD CAUTION
Data Sheet ADG5208/ADG5209 ABSOLUTE MAXIMUM RATINGS Table 7 Parameter Rating ESD CAUTION
link to page 8 link to page 8
TA = 25°C, unless otherwise noted.
Table 7.
Stresses at or above those listed under Absolute Maximum
Parameter Rating
Ratings may cause permanent damage to the product. This is a V stress rating only; functional operation of the product at these DD to VSS 48 V or any other conditions above those indicated in the operational VDD to GND −0.3 V to +48 V section of this specification is not implied. Operation beyond VSS to GND +0.3 V to −48 V the maximum operating conditions for extended periods may Analog Inputs1 VSS − 0.3 V to VDD + 0.3 V or 30 mA, whichever occurs first affect product reliability. Digital Inputs1 VSS − 0.3 V to VDD + 0.3 V or Only one absolute maximum rating can be applied at any 30 mA, whichever occurs first one time. Peak Current, Sx, D, or Dx Pins
ESD CAUTION
ADG5208 126 mA (pulsed at 1 ms, 10% duty cycle maximum) ADG5209 92 mA (pulsed at 1 ms, 10% duty cycle maximum) Continuous Current, Sx, D, or Data + 15% Dx Pins2 Temperature Range Operating −40°C to +125°C Storage −65°C to +150°C Junction Temperature 150°C Thermal Impedance, θJA 16-Lead TSSOP (4-Layer 112.6°C/W Board) 16-Lead LFCSP (4-Layer 30.4°C/W Board) Reflow Soldering Peak 260(+0/−5)°C Temperature, Pb Free HBM ESD I/O Port to Supplies 8 kV I/O Port to I/O Port 2 kV All Other Pins 8 kV 1 Overvoltages at the Ax, EN, Sx, D, and Dx pins are clamped by internal diodes. Limit current to the maximum ratings given. 2 See Table 5 and Table 6. Rev. C | Page 9 of 24 Document Outline Features Applications Functional Block Diagrams General Description Product Highlights Table of Contents Revision History Specifications ±15 V Dual Supply ±20 V Dual Supply 12 V Single Supply 36 V Single Supply Continuous Current per Channel, Sx, D, or Dx Pin Configurations and Function Descriptions Typical Performance Characteristics Test Circuits Terminology Trench Isolation Applications Information Outline Dimensions Ordering Guide
