Datasheet ADG5208, ADG5209 (Analog Devices) - 10
DescriptionHigh Voltage Latch-Up Proof, 4-/8-Channel Multiplexers
Pages / Page24 / 10 — ADG5208/ADG5209. Data Sheet. PIN CONFIGURATIONS AND FUNCTION …
RevisionC
File Format / SizePDF / 472 Kb
ADG5208/ADG5209. Data Sheet. PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS. 16 A1. 12 GND. 15 A2. S1 2. 11 V. ADG5208. VSS 3. 14 GND. TOP VIEW
ADG5208/ADG5209 Data Sheet PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS 16 A1 12 GND 15 A2 S1 2 11 V ADG5208 VSS 3 14 GND TOP VIEW
ADG5208/ADG5209 Data Sheet PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS N 0 1 2 E A A A 6 5 4 3 1 1 1 1 A0 1 16 A1 V 1 12 GND SS EN 2 15 A2 S1 2 11 V ADG5208 DD VSS 3 14 GND ADG5208 TOP VIEW S2 3 10 S5 (Not to Scale) S1 4 13 V TOP VIEW DD S3 4 9 S6 S2 (Not to Scale) 5 12 S5 S3 6 11 S6 5 6 7 8 S4 7 10 S7
2
4 D 8 7
00
S S S D 8 9 S8
7-
NOTES
991 0
1. THE EXPOSED PAD IS CONNECTED INTERNALLY. FOR INCREASED RELIABILITY OF THE SOLDER JOINTS AND
03 0
MAXIMUM THERMAL CAPABILITY, IT IS RECOMMENDED
7-
THAT THE PAD BE SOLDERED TO THE SUBSTRATE, V
91
SS.
09 Figure 2. ADG5208 Pin Configuration (TSSOP) Figure 3. ADG5208 Pin Configuration (LFCSP)
Table 8. ADG5208 Pi n Function Descriptions Pin No. TSSOP LFCSP Mnemonic Description
1 15 A0 Logic Control Input. 2 16 EN Active High Digital Input. When low, the device is disabled and all switches are off. When high, the Ax logic inputs determine the on switches. 3 1 VSS Most Negative Power Supply Potential. In single-supply applications, this pin can be connected to ground. 4 2 S1 Source Terminal 1. This pin can be an input or an output. 5 3 S2 Source Terminal 2. This pin can be an input or an output. 6 4 S3 Source Terminal 3. This pin can be an input or an output. 7 5 S4 Source Terminal 4. This pin can be an input or an output. 8 6 D Drain Terminal. This pin can be an input or an output. 9 7 S8 Source Terminal 8. This pin can be an input or an output. 10 8 S7 Source Terminal 7. This pin can be an input or an output. 11 9 S6 Source Terminal 6. This pin can be an input or an output. 12 10 S5 Source Terminal 5. This pin can be an input or an output. 13 11 VDD Most Positive Power Supply Potential. 14 12 GND Ground (0 V) Reference. 15 13 A2 Logic Control Input. 16 14 A1 Logic Control Input. EP Exposed Pad The exposed pad is connected internally. For increased reliability of the solder joints and maximum thermal capability, it is recommended that the pad be soldered to the substrate, VSS.
Table 9. ADG5208 Truth Table A2 A1 A0 EN On Switch
X1 X1 X1 0 None 0 0 0 1 1 0 0 1 1 2 0 1 0 1 3 0 1 1 1 4 1 0 0 1 5 1 0 1 1 6 1 1 0 1 7 1 1 1 1 8 1 X is don’t care. Rev. C | Page 10 of 24 Document Outline Features Applications Functional Block Diagrams General Description Product Highlights Table of Contents Revision History Specifications ±15 V Dual Supply ±20 V Dual Supply 12 V Single Supply 36 V Single Supply Continuous Current per Channel, Sx, D, or Dx Pin Configurations and Function Descriptions Typical Performance Characteristics Test Circuits Terminology Trench Isolation Applications Information Outline Dimensions Ordering Guide
