Datasheet ADG5208-EP, ADG5209-EP (Analog Devices) - 5
DescriptionHigh Voltage Latch-Up Proof, 4-/8-Channel Multiplexers
Pages / Page20 / 5 — Enhanced Product. ADG5208-EP/ADG5209-EP. Parameter. 25°C. −40°C to +85°C …
RevisionADG5208-EP/ADG5209-EP: Enhanced Data Sheet
File Format / SizePDF / 424 Kb
Enhanced Product. ADG5208-EP/ADG5209-EP. Parameter. 25°C. −40°C to +85°C −55°C to +125°C Unit. Test Conditions/Comments
Enhanced Product ADG5208-EP/ADG5209-EP Parameter 25°C −40°C to +85°C −55°C to +125°C Unit Test Conditions/Comments
link to page 16 link to page 16 link to page 16 link to page 16 link to page 16 link to page 16
−3 dB Bandwidth RL = 50 Ω, CL = 5 pF; see Figure 30 ADG5208-EP 121 MHz typ ADG5209-EP 225 MHz typ Insertion Loss −5.6 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 30 CS (Off) 2.8 pF typ VS = 0 V, f = 1 MHz CD (Off) ADG5208-EP 33 pF typ VS = 0 V, f = 1 MHz ADG5209-EP 17 pF typ VS = 0 V, f = 1 MHz CD (On), CS (On) ADG5208-EP 36 pF typ VS = 0 V, f = 1 MHz ADG5209-EP 21 pF typ VS = 0 V, f = 1 MHz POWER REQUIREMENTS VDD = +22 V, VSS = −22 V IDD 50 µA typ Digital inputs = 0 V or VDD 70 120 µA max ISS 0.001 µA typ Digital inputs = 0 V or VDD 1 µA max VDD/VSS ±9/±22 V min/V max GND = 0 V 1 Guaranteed by design; not subject to production test.
12 V SINGLE SUPPLY
VDD = 12 V ± 10%, VSS = 0 V, GND = 0 V, unless otherwise noted.
Table 3. Parameter 25°C −40°C to +85°C −55°C to +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 V to VDD V On Resistance, RON 350 Ω typ VS = 0 V to 10 V, IS = −1 mA; see Figure 26 500 610 700 Ω max VDD = 10.8 V, VSS = 0 V On-Resistance Match Between 5 Ω typ VS = 0 V to 10 V, IS = −1 mA Channels, ∆RON 20 22 24 Ω max On-Resistance Flatness, RFLAT (ON) 160 Ω typ VS = 0 V to 10 V, IS = −1 mA 280 335 370 Ω max LEAKAGE CURRENTS VDD = 13.2 V, VSS = 0 V Source Off Leakage, IS (Off) ±0.005 nA typ VS = 1 V/10 V, VD = 10 V/1 V; see Figure 28 ±0.1 ±0.2 ±0.4 nA max Drain Off Leakage, ID (Off) ±0.005 nA typ VS = 1 V/10 V, VD = 10 V/1 V; see Figure 28 ±0.1 ±0.4 ±1.4 nA max Channel On Leakage, ID (On), IS (On) ±0.01 nA typ VS = VD = 1 V/10 V; see Figure 25 ±0.2 ±0.5 ±1.4 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH 0.002 µA typ VIN = VGND or VDD ±0.1 µA max Digital Input Capacitance, CIN 3 pF typ Rev. C | Page 5 of 20 Document Outline Features Applications General Description Functional Block Diagram Product Highlights Table of Contents Revision History Specifications ±15 V Dual Supply ±20 V Dual Supply 12 V Single Supply 36 V Single Supply Continuous Current per Channel, Sx, D, or Dx Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Test Circuits Outline Dimensions Ordering Guide
