Datasheet ADG5208-EP, ADG5209-EP (Analog Devices) - 10
DescriptionHigh Voltage Latch-Up Proof, 4-/8-Channel Multiplexers
Pages / Page20 / 10 — ADG5208-EP/ADG5209-EP. Enhanced Product. PIN CONFIGURATIONS AND FUNCTION …
RevisionADG5208-EP/ADG5209-EP: Enhanced Data Sheet
File Format / SizePDF / 424 Kb
ADG5208-EP/ADG5209-EP. Enhanced Product. PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS. 16 A1. 15 A2. VSS 3. 14 GND. ADG5208-EP. 13 V
ADG5208-EP/ADG5209-EP Enhanced Product PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS 16 A1 15 A2 VSS 3 14 GND ADG5208-EP 13 V
ADG5208-EP/ADG5209-EP Enhanced Product PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS A0 1 16 A1 EN 2 15 A2 VSS 3 14 GND ADG5208-EP S1 4 13 V TOP VIEW DD S2 (Not to Scale) 5 12 S5 S3 6 11 S6 S4 7 10 S7
002
D 8 9 S8
11475- Figure 2. ADG5208-EP Pin Configuration (TSSOP)
Table 8. ADG5208-EP Pin Function Descriptions Pin No. Mnemonic Description
1 A0 Logic Control Input. 2 EN Active High Digital Input. When low, the device is disabled and all switches are off. When high, the Ax logic inputs determine the on switches. 3 VSS Most Negative Power Supply Potential. In single-supply applications, this pin can be connected to ground. 4 S1 Source Terminal 1. This pin can be an input or an output. 5 S2 Source Terminal 2. This pin can be an input or an output. 6 S3 Source Terminal 3. This pin can be an input or an output. 7 S4 Source Terminal 4. This pin can be an input or an output. 8 D Drain Terminal. This pin can be an input or an output. 9 S8 Source Terminal 8. This pin can be an input or an output. 10 S7 Source Terminal 7. This pin can be an input or an output. 11 S6 Source Terminal 6. This pin can be an input or an output. 12 S5 Source Terminal 5. This pin can be an input or an output. 13 VDD Most Positive Power Supply Potential. 14 GND Ground (0 V) Reference. 15 A2 Logic Control Input. 16 A1 Logic Control Input.
Table 9. ADG5208-EP Truth Table A2 A1 A0 EN On Switch
X1 X1 X1 0 None 0 0 0 1 1 0 0 1 1 2 0 1 0 1 3 0 1 1 1 4 1 0 0 1 5 1 0 1 1 6 1 1 0 1 7 1 1 1 1 8 1 X is don’t care. Rev. C | Page 10 of 20 Document Outline Features Applications General Description Functional Block Diagram Product Highlights Table of Contents Revision History Specifications ±15 V Dual Supply ±20 V Dual Supply 12 V Single Supply 36 V Single Supply Continuous Current per Channel, Sx, D, or Dx Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Test Circuits Outline Dimensions Ordering Guide
