Datasheet ADG5233, ADG5234 (Analog Devices) - 3
DescriptionHigh Voltage Latch-Up Proof, Triple/Quad SPDT Switches
Pages / Page22 / 3 — Data Sheet. ADG5233/ADG5234. SPECIFICATIONS ±15 V DUAL SUPPLY. Table 1. …
RevisionD
File Format / SizePDF / 478 Kb
Data Sheet. ADG5233/ADG5234. SPECIFICATIONS ±15 V DUAL SUPPLY. Table 1. Parameter. 25°C. −40°C to +85°C. −40°C to +125°C. Unit
Data Sheet ADG5233/ADG5234 SPECIFICATIONS ±15 V DUAL SUPPLY Table 1 Parameter 25°C −40°C to +85°C −40°C to +125°C Unit
link to page 16 link to page 16 link to page 16 link to page 16 link to page 17 link to page 17 link to page 17 link to page 17 link to page 17 link to page 16 link to page 16 link to page 16 link to page 16 link to page 4
VDD = +15 V ± 10%, VSS = −15 V ± 10%, GND = 0 V, unless otherwise noted.
Table 1. Parameter 25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range VDD to VSS V On Resistance, RON 160 Ω typ VS = ±10 V, IS = −1 mA; see Figure 28 200 250 280 Ω max VDD = +13.5 V, VSS = −13.5 V On-Resistance Match Between 3.5 Ω typ VS = ±10 V, IS = −1 mA Channels, ∆RON 8 9 10 Ω max On-Resistance Flatness, RFLAT (ON) 38 Ω typ VS = ±10 V, IS = −1 mA 50 65 70 Ω max LEAKAGE CURRENTS VDD = +16.5 V, VSS = −16.5 V Source Off Leakage, IS (Off) ±0.02 nA typ VS = ±10 V, VD =  10 V; see Figure 30 ±0.1 ±0.2 ±0.4 nA max Drain Off Leakage, ID (Off) ±0.02 nA typ VS = ±10 V, VD =  10 V; see Figure 30 ±0.1 ±0.2 ±0.4 nA max Channel On Leakage, ID (On), IS (On) ±0.08 nA typ VS = VD = ±10 V; see Figure 26 ±0.2 ±0.3 ±0.9 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH 0.002 µA typ VIN = VGND or VDD ±0.1 µA max Digital Input Capacitance, CIN 3 pF typ DYNAMIC CHARACTERISTICS1 Transition Time, tTRANSITION 125 ns typ RL = 300 Ω, CL = 35 pF 160 190 215 ns max VS = 10 V; see Figure 33 tON (EN) 145 ns typ RL = 300 Ω, CL = 35 pF 175 210 240 ns max VS = 10 V; see Figure 35 tOFF (EN) 125 ns typ RL = 300 Ω, CL = 35 pF 155 170 180 ns max VS = 10 V; see Figure 35 Break-Before-Make Time Delay, tD 45 ns typ RL = 300 Ω, CL = 35 pF 25 ns min VS1 = VS2 = 10 V; see Figure 34 Charge Injection, QINJ 0.4 pC typ VS = 0 V, RS = 0 Ω, CL = 1 nF; see Figure 36 Off Isolation −76 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 31 Channel-to-Channel Crosstalk −87 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; Figure 29 −3 dB Bandwidth 355 MHz typ RL = 50 Ω, CL = 5 pF; see Figure 32 Insertion Loss −6.4 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 32 CS (Off) 2.8 pF typ VS = 0 V, f = 1 MHz CD (Off) 9 pF typ VS = 0 V, f = 1 MHz CD (On), CS (On) 13 pF typ VS = 0 V, f = 1 MHz Rev. D | Page 3 of 22 Document Outline Features Applications Functional Block Diagrams General Description Product Highlights Table of Contents Revision History Specifications ±15 V Dual Supply ±20 V Dual Supply 12 V Single Supply 36 V Single Supply Continuous Current per Channel, Sx or Dx Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Test Circuits Terminology Trench Isolation Applications Information Outline Dimensions Ordering Guide
