Datasheet ADG5236 (Analog Devices)
DescriptionHigh Voltage Latch-Up Proof, Dual SPDT Switches
Pages / Page20 / 1 — High Voltage Latch-Up Proof,. Dual SPDT Switches. Data Sheet. ADG5236. …
RevisionB
File Format / SizePDF / 398 Kb
High Voltage Latch-Up Proof,. Dual SPDT Switches. Data Sheet. ADG5236. FEATURES. FUNCTIONAL BLOCK DIAGRAMS
Datasheet ADG5236 Analog Devices, Revision: B
High Voltage Latch-Up Proof, Dual SPDT Switches Data Sheet ADG5236 FEATURES FUNCTIONAL BLOCK DIAGRAMS Latch-up immune under all circumstances ADG5236 2.5 pF off source capacitance S1A 12 pF off drain capacitance D1 −0.6 pC charge injection S1B Low leakage: 0.4 nA maximum at 85°C IN1 ±9 V to ±22 V dual-supply operation 9 V to 40 V single-supply operation IN2 48 V supply maximum ratings S2A Fully specified at ±15 V, ±20 V, +12 V, and +36 V D2 VSS to VDD analog signal range S2B APPLICATIONS
001
High voltage signal routing SWITCHES SHOWN FOR A LOGIC 1 INPUT.
09769-
Automatic test equipment
Figure 1. TSSOP Package
Analog front-end circuits Precision data acquisition ADG5236 Industrial instrumentation S1A S2A Amplifier gain select D1 D2 Relay replacement S1B S2B LOGIC IN1 IN2 EN
002
09769- Figure 2. LFCSP Package
GENERAL DESCRIPTION PRODUCT HIGHLIGHTS
The ADG5236 is a monolithic CMOS device containing two 1. Trench Isolation Guards Against Latch-Up. independently selectable single-pole/double throw (SPDT) A dielectric trench separates the P and N channel switches. An EN input on the LFCSP package enables or transistors thereby preventing latch-up even under severe disables the device. When disabled, all channels switch off. Each overvoltage conditions. switch conducts equally wel in both directions when on and 2. Ultralow Capacitance and <1 pC Charge Injection. has an input signal range that extends to the supplies. In the off 3. Dual-Supply Operation. condition, signal levels up to the supplies are blocked. Both For applications where the analog signal is bipolar, the switches exhibit break-before-make switching action for use in ADG5236 can be operated from dual supplies up to ±22 V. multiplexer applications. 4. Single-Supply Operation. The ultralow capacitance and charge injection of these switches For applications where the analog signal is unipolar, the make them ideal solutions for data acquisition and sample-and- ADG5236 can be operated from a single rail power supply hold applications, where low glitch and fast settling are required. up to 40 V. Fast switching speed together with high signal bandwidth make 5. 3 V Logic-Compatible Digital Inputs. the device suitable for video signal switching. VINH = 2.0 V, VINL = 0.8 V. 6. No VL Logic Power Supply Required.
Rev. B Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2011–2013 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications Functional Block Diagrams General Description Product Highlights Revision History Specifications ±15 V Dual Supply ±20 V Dual Supply 12 V Single Supply 36 V Single Supply Continuous Current per Channel, SxA, SxB, or Dx Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Truth Tables for Switches Typical Performance Characteristics Test Circuits Terminology Trench Isolation Applications Information Outline Dimensions Ordering Guide
