Datasheet ADG5236 (Analog Devices) - 5
DescriptionHigh Voltage Latch-Up Proof, Dual SPDT Switches
Pages / Page20 / 5 — Data Sheet. ADG5236. Parameter. 25°C −40°C to +85°C −40°C to +125°C Unit. …
RevisionB
File Format / SizePDF / 398 Kb
Data Sheet. ADG5236. Parameter. 25°C −40°C to +85°C −40°C to +125°C Unit. Test Conditions/Comments. 12 V SINGLE SUPPLY
Data Sheet ADG5236 Parameter 25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments 12 V SINGLE SUPPLY
link to page 14 link to page 14 link to page 14 link to page 14 link to page 15 link to page 15 link to page 15 link to page 15 link to page 15 link to page 6
CS (Off) 2.5 pF typ VS = 0 V, f = 1 MHz CD (Off) 12 pF typ VS = 0 V, f = 1 MHz CD (On), CS (On) 15 pF typ VS = 0 V, f = 1 MHz POWER REQUIREMENTS VDD = +22 V, VSS = −22 V IDD 50 µA typ Digital inputs = 0 V or VDD 70 110 µA max ISS 0.001 µA typ Digital inputs = 0 V or VDD 1 µA max VDD/VSS ±9/±22 V min/V max GND = 0 V 1 Guaranteed by design; not subject to production test.
12 V SINGLE SUPPLY
VDD = 12 V ± 10%, VSS = 0 V, GND = 0 V, unless otherwise noted.
Table 3. Parameter 25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 V to VDD V max On Resistance, RON 350 Ω typ VS = 0 V to 10 V, IS = −1 mA, see Figure 25 500 610 700 Ω max VDD = 10.8 V, VSS = 0 V On-Resistance Match 3 Ω typ VS = 0 V to 10 V, IS = −1 mA Between Channels, ∆RON 20 21 22 Ω max On-Resistance Flatness, RFLAT (ON) 145 Ω typ VS = 0 V to 10 V, IS = −1 mA 280 335 370 Ω max LEAKAGE CURRENTS VDD = 13.2 V, VSS = 0 V Source Off Leakage, IS (Off) 0.01 nA typ VS = 1 V/10 V, VD = 10 V/1 V, see Figure 27 0.1 0.2 0.4 nA max Drain Off Leakage, ID (Off) 0.01 nA typ VS = 1 V/10 V, VD = 10 V/1 V, see Figure 27 0.1 0.4 1.2 nA max Channel On Leakage, ID (On), IS (On) 0.02 nA typ VS = VD = 1 V/10 V, see Figure 24 0.2 0.4 1.2 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH 0.002 µA typ VIN = VGND or VDD ±0.1 µA max Digital Input Capacitance, CIN 3 pF typ DYNAMIC CHARACTERISTICS1 Transition Time, tTRANSITION 220 ns typ RL = 300 Ω, CL = 35 pF 390 430 490 ns max VS = 8 V, see Figure 30 tON 275 ns typ RL = 300 Ω, CL = 35 pF 380 440 510 ns max VS = 8 V, see Figure 32 tOFF 160 ns typ RL = 300 Ω, CL = 35 pF 195 225 245 ns max VS = 8 V, see Figure 32 Break-Before-Make Time Delay, tD 145 ns typ RL = 300 Ω, CL = 35 pF 65 ns min VS1 = VS2 = 8 V, see Figure 31 Charge Injection, QINJ −0.6 pC typ VS = 6 V, RS = 0 Ω, CL = 1 nF, see Figure 33 Rev. B | Page 5 of 20 Document Outline Features Applications Functional Block Diagrams General Description Product Highlights Revision History Specifications ±15 V Dual Supply ±20 V Dual Supply 12 V Single Supply 36 V Single Supply Continuous Current per Channel, SxA, SxB, or Dx Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Truth Tables for Switches Typical Performance Characteristics Test Circuits Terminology Trench Isolation Applications Information Outline Dimensions Ordering Guide
