Datasheet ADG5236 (Analog Devices) - 6
DescriptionHigh Voltage Latch-Up Proof, Dual SPDT Switches
Pages / Page20 / 6 — ADG5236. Data Sheet. Parameter. 25°C. −40°C to +85°C −40°C to +125°C …
RevisionB
File Format / SizePDF / 398 Kb
ADG5236. Data Sheet. Parameter. 25°C. −40°C to +85°C −40°C to +125°C Unit. Test Conditions/Comments. 36 V SINGLE SUPPLY
ADG5236 Data Sheet Parameter 25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments 36 V SINGLE SUPPLY
link to page 14 link to page 14 link to page 14 link to page 14 link to page 14 link to page 14 link to page 14 link to page 14 link to page 15 link to page 15 link to page 7
Off Isolation −90 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz, see Figure 28 Channel-to-Channel Crosstalk −90 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz, see Figure 26 −3 dB Bandwidth 185 MHz typ RL = 50 Ω, CL = 5 pF, see Figure 29 Insertion Loss −11 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz, see Figure 29 CS (Off) 3 pF typ VS = 6 V, f = 1 MHz CD (Off) 16 pF typ VS = 6 V, f = 1 MHz CD (On), CS (On) 16 pF typ VS = 6 V, f = 1 MHz POWER REQUIREMENTS VDD = 13.2 V IDD 40 µA typ Digital inputs = 0 V or VDD 65 µA max VDD 9/40 V min/V max GND = 0 V, VSS = 0 V 1 Guaranteed by design; not subject to production test.
36 V SINGLE SUPPLY
VDD = 36 V ± 10%, VSS = 0 V, GND = 0 V, unless otherwise noted.
Table 4. Parameter 25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 V to VDD V max On Resistance, RON 150 Ω typ VS = 0 V to 30 V, IS = −1 mA, see Figure 25 170 215 245 Ω max VDD = 32.4 V, VSS = 0 V On-Resistance Match 1.4 Ω typ VS = 0 V to 30 V, IS = −1 mA Between Channels, ∆RON 8 9 10 Ω max On-Resistance Flatness, RFLAT(ON) 35 Ω typ VS = 0 V to 30 V, IS = −1 mA 50 60 65 Ω max LEAKAGE CURRENTS VDD = 39.6 V, VSS = 0 V Source Off Leakage, IS (Off) 0.01 nA typ VS = 1 V/30 V, VD = 30 V/1 V, see Figure 27 0.1 0.2 0.4 nA max Drain Off Leakage, ID (Off) 0.01 nA typ VS = 1 V/30 V, VD = 30 V/1 V, see Figure 27 0.1 0.4 1.2 nA max Channel On Leakage, ID (On), IS (On) 0.02 nA typ VS = VD = 1 V/30 V, see Figure 24 0.2 0.4 1.2 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH 0.002 µA typ VIN = VGND or VDD ±0.1 µA max Digital Input Capacitance, CIN 3 pF typ DYNAMIC CHARACTERISTICS1 Transition Time, tTRANSITION 180 ns typ RL = 300 Ω, CL = 35 pF 250 275 305 ns max VS = 18 V, see Figure 30 tON 170 ns typ RL = 300 Ω, CL = 35 pF 225 265 295 ns max VS = 18 V, see Figure 32 Rev. B | Page 6 of 20 Document Outline Features Applications Functional Block Diagrams General Description Product Highlights Revision History Specifications ±15 V Dual Supply ±20 V Dual Supply 12 V Single Supply 36 V Single Supply Continuous Current per Channel, SxA, SxB, or Dx Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Truth Tables for Switches Typical Performance Characteristics Test Circuits Terminology Trench Isolation Applications Information Outline Dimensions Ordering Guide
