Datasheet ADG5433, ADG5434 (Analog Devices) - 6
DescriptionHigh Voltage Latch-Up Proof, Triple/Quad SPDT Switches
Pages / Page24 / 6 — ADG5433/ADG5434. Data Sheet. Parameter. 25°C. −40°C to +85°C −40°C to …
RevisionC
File Format / SizePDF / 428 Kb
ADG5433/ADG5434. Data Sheet. Parameter. 25°C. −40°C to +85°C −40°C to +125°C Unit. Test Conditions/Comments. 36 V SINGLE SUPPLY
ADG5433/ADG5434 Data Sheet Parameter 25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments 36 V SINGLE SUPPLY
link to page 16 link to page 16 link to page 16 link to page 16 link to page 16 link to page 16 link to page 17 link to page 17 link to page 17 link to page 7
Channel-to-Channel Crosstalk −60 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 28 Total Harmonic Distortion + Noise 0.1 % typ RL = 1 kΩ, 6 V p-p, f = 20 Hz to 20 kHz; see Figure 30 −3 dB Bandwidth 150 MHz typ RL = 50 Ω, CL = 5 pF; see Figure 31 Insertion Loss −0.8 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 31 CS (Off) 18 pF typ VS = 6 V, f = 1 MHz CD (Off) 28 pF typ VS = 6 V, f = 1 MHz CD (On), CS (On) 54 pF typ VS = 6 V, f = 1 MHz POWER REQUIREMENTS VDD = 13.2 V IDD 40 µA typ Digital inputs = 0 V or VDD 50 65 µA max VDD 9/40 V min/V max GND = 0 V, VSS = 0 V 1 Guaranteed by design; not subject to production test.
36 V SINGLE SUPPLY
VDD = 36 V ± 10%, VSS = 0 V, GND = 0 V, unless otherwise noted.
Table 4. Parameter 25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 V to VDD V On Resistance, RON 14.5 Ω typ VS = 0 V to 30 V, IS = −10 mA; see Figure 27 16 19 23 Ω max VDD = 32.4 V, VSS = 0 V On-Resistance Match Between 0.3 Ω typ VS = 0 V to 30 V, IS = −10 mA Channels, ∆RON 0.8 1.3 1.4 Ω max On-Resistance Flatness, RFLAT (ON) 3.5 Ω typ VS = 0 V to 30 V, IS = −10 mA 4.3 5.5 6.5 Ω max LEAKAGE CURRENTS VDD = 39.6 V, VSS = 0 V Source Off Leakage, IS (Off) ±0.05 nA typ VS = 1 V/30 V, VD = 30 V/1 V ±0.25 ±1 ±7 nA max Drain Off Leakage, ID (Off) ±0.1 nA typ VS = 1 V/30 V, VD = 30 V/1 V ±0.4 ±4 ±30 nA max Channel On Leakage, ID (On), IS (On) ±0.1 nA typ VS = VD = 1 V/30 V; see Figure 26 ±0.4 ±4 ±30 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH 0.002 µA typ VIN = VGND or VDD ±0.1 µA max Digital Input Capacitance, CIN 6 pF typ DYNAMIC CHARACTERISTICS1 Transition Time, tTRANSITION 180 ns typ RL = 300 Ω, CL = 35 pF 262 274 289 ns max VS = 18 V tON (EN) 176 ns typ RL = 300 Ω, CL = 35 pF 216 238 268 ns max VS = 18 V; see Figure 34 tOFF (EN) 98 ns typ RL = 300 Ω, CL = 35 pF 123 127 129 ns max VS = 18 V; see Figure 34 Break-Before-Make Time Delay, tD 50 ns typ RL = 300 Ω, CL = 35 pF 21 ns min VS1 = VS2 = 18 V; see Figure 33 Rev. C | Page 6 of 24 Document Outline Features Applications Functional Block Diagrams General Description Product Highlights Revision History Specifications ±15 V Dual Supply ±20 V Dual Supply 12 V Single Supply 36 V Single Supply Continuous Current per Channel, Sx or Dx Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Test Circuits Terminology Trench Isolation Applications Information Outline Dimensions Ordering Guide
