Datasheet ADG5433W (Analog Devices) - 9
DescriptionHigh Voltage, Latch-up Proof, Triple SPDT Switches
Pages / Page20 / 9 — Data Sheet. ADG5433W. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. GND. …
File Format / SizePDF / 387 Kb
Data Sheet. ADG5433W. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. GND. S1A. IN1. S1B. ADG5433W 13 VSS. TOP VIEW. S2B. S3B. (Not to Scale). S2A
Data Sheet ADG5433W PIN CONFIGURATION AND FUNCTION DESCRIPTIONS GND S1A IN1 S1B ADG5433W 13 VSS TOP VIEW S2B S3B (Not to Scale) S2A
link to page 9
Data Sheet ADG5433W PIN CONFIGURATION AND FUNCTION DESCRIPTIONS V 1 16 DD GND S1A 2 15 IN1 D1 3 14 EN S1B 4 ADG5433W 13 VSS TOP VIEW S2B 5 12 S3B (Not to Scale) D2 6 11 D3 S2A 7 10 S3A IN2 8 9 IN3
003 10656- Figure 2. Pin Configuration
Table 7. Pin Function Descriptions Pin No. Mnemonic Description
1 VDD Most Positive Power Supply Potential. 2 S1A Source Terminal 1A. This pin can be an input or an output. 3 D1 Drain Terminal 1. This pin can be an input or an output. 4 S1B Source Terminal 1B. This pin can be an input or an output. 5 S2B Source Terminal 2B. This pin can be an input or an output. 6 D2 Drain Terminal 2. This pin can be an input or an output. 7 S2A Source Terminal 2A. This pin can be an input or an output. 8 IN2 Logic Control Input 2. 9 IN3 Logic Control Input 3. 10 S3A Source Terminal 3A. This pin can be an input or an output. 11 D3 Drain Terminal 3. This pin can be an input or an output. 12 S3B Source Terminal 3B. This pin can be an input or an output. 13 VSS Most Negative Power Supply Potential. In single-supply applications, this pin must be connected to ground. 14 EN Active Low Digital Input. When high, the device is disabled and all switches are off. When low, the INx logic inputs determine the on switches. 15 IN1 Logic Control Input 1. 16 GND Ground (0 V) Reference.
Table 8. Truth Table EN INx SxA SxB
1 X1 Off Off 0 0 Off On 0 1 On Off 1 X = don’t care. Rev. 0 | Page 9 of 20 Document Outline Features Applications Functional Block Diagram General Description Product Highlights Revision History Specifications ±15 V Dual Supply ±20 V Dual Supply 12 V Single Supply 36 V Single Supply Continuous Current per Channel, Sx or Dx Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Test Circuits Terminology Trench Isolation Applications Information Outline Dimensions Ordering Guide Automotive Products
