Datasheet ADG5433W (Analog Devices) - 10
Description | High Voltage, Latch-up Proof, Triple SPDT Switches |
Pages / Page | 20 / 10 — ADG5433W. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. A = 25°C. DD = … |
Revision | A |
File Format / Size | PDF / 387 Kb |
ADG5433W. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. A = 25°C. DD = +9V. DD = +10V. SS = –9V. SS = –10V. VDD = +11V. VSS = –11V. ANCE
ADG5433W Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 25 16 T T A = 25°C A = 25°C V V DD = +9V DD = +10V 14 V V SS = –9V SS = –10V 20 12 ) VDD = +11V ) (Ω VSS = –11V (Ω 10 15 ANCE ANCE V T T DD = 32.4V 8 V V DD = 36V DD = 39.6V V IS IS SS = 0V V V SS = 0V SS = 0V S S 10 VDD = +13.5V 6 N RE VSS = –13.5V VDD = +15V N RE O V V O SS = –15V DD = +16.5V VSS = –16.5V 4 5 2 0 0 –18 –14 –10 –6 –2 2 6 10 14 18 0 5 10 15 20 25 30 35 40 45
047 046
VS, VD (V) V
10656-
S, VD (V)
10656- Figure 3. On Resistance as a Function of VS, VD (Dual Supply) Figure 6. On Resistance as a Function of VS, VD (Single Supply)
16 25 TA = 25°C 14 20 VDD = +18V 12 V ) SS = –18V ) TA = +125°C (Ω (Ω 10 15 TA = +85°C ANCE ANCE T 8 T V V IS DD = +20V DD = +22V IS TA = +25°C S V V SS = –20V SS = –22V S 10 6 N RE N RE TA = –40°C O O 4 5 2 VDD = +15V VSS = –15V 0 0 –25 –20 –15 –10 –5 0 5 10 15 20 25 –15 –10 –5 0 5 10 15
048 049
VS, VD (V) VS, VD (V)
10656- 10656- Figure 4. On Resistance as a Function of VS, VD (Dual Supply) Figure 7. On Resistance as a Function of VS (VD) for Different Temperatures, ±15 V Dual Supply
35 25 T V A = 25°C DD = +20V V V DD = 10V V SS = –20V V DD = 10.8V 30 SS = 0V VSS = 0V VDD = 9V 20 VSS = 0V 25 ) ) (Ω (Ω 15 TA = +125°C 20 ANCE T V T A = +85°C DD = 11V IS SISTANCE V 15 SS = 0V V S DD = 12V T RE V 10 A = +25°C SS = 0V V N DD = 13.2V V N RE O SS = 0V O T 10 A = –40°C 5 5 0 0 0 2 4 6 8 10 12 14
044
045
VS, VD (V)
10656-
VS, VD (V)
10656- Figure 5. On Resistance as a Function of VS, VD (Single Supply) Figure 8. On Resistance as a Function of VS (VD) for Different Temperatures, ±20 V Dual Supply Rev. A | Page 10 of 20 Document Outline Features Applications Functional Block Diagram General Description Product Highlights Revision History Specifications ±15 V Dual Supply ±20 V Dual Supply 12 V Single Supply 36 V Single Supply Continuous Current per Channel, Sx or Dx Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Test Circuits Terminology Trench Isolation Applications Information Outline Dimensions Ordering Guide Automotive Products
