Datasheet ADG5404 (Analog Devices) - 8
DescriptionHigh Voltage, Latch-up Proof, 4-Channel Multiplexer
Pages / Page20 / 8 — ADG5404. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 6. Parameter. …
RevisionB
File Format / SizePDF / 536 Kb
ADG5404. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 6. Parameter. Rating. ESD CAUTION
ADG5404 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 6 Parameter Rating ESD CAUTION
link to page 7
TA = 25°C, unless otherwise noted.
Table 6. Parameter Rating
Stresses at or above those listed under Absolute Maximum V Ratings may cause permanent damage to the product. This is a DD to VSS 48 V V stress rating only; functional operation of the product at these DD to GND −0.3 V to +48 V V or any other conditions above those indicated in the operational SS to GND +0.3 V to −48 V Analog Inputs1 V section of this specification is not implied. Operation beyond SS − 0.3 V to VDD + 0.3 V or 30 mA, whichever occurs first the maximum operating conditions for extended periods may Digital Inputs1 V affect product reliability. SS − 0.3 V to VDD + 0.3 V or 30 mA, whichever occurs first Only one absolute maximum rating can be applied at any Peak Current, Sx or D Pins 515 mA (pulsed at 1 ms, one time. 10% duty cycle maximum) Continuous Current, S or D2 Data + 15%
ESD CAUTION
Operating Temperature Range −40°C to +125°C Storage Temperature Range −65°C to +150°C Junction Temperature 150°C Thermal Impedance, θJA 16-Lead TSSOP, θJA Thermal 112.6°C/W Impedance (4-Layer Board) 16-Lead LFCSP, θJA Thermal 30.4°C/W Impedance (4-Layer Board) Reflow Soldering Peak 260(+0/−5)°C Temperature, Pb Free 1 Overvoltages at the Sx and D pins are clamped by internal diodes. Limit current to the maximum ratings given. 2 See Table 5. Rev. B | Page 8 of 20 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY ±20 V DUAL SUPPLY +12 V SINGLE SUPPLY +36 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, S OR D ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TRUTH TABLE TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY TRENCH ISOLATION APPLICATIONS INFORMATION OUTLINE DIMENSIONS ORDERING GUIDE
