Datasheet ADG1414 (Analog Devices)
Description | 9.5 Ω RON ±15 V/+12 V/±5 V iCMOS Serially-Controlled Octal SPST Switches |
Pages / Page | 19 / 1 — 9.5 Ω RON, ±15 V/+12 V/±5 V. CMOS,. Serially-Controlled Octal SPST … |
Revision | B |
File Format / Size | PDF / 536 Kb |
9.5 Ω RON, ±15 V/+12 V/±5 V. CMOS,. Serially-Controlled Octal SPST Switches. Data Sheet. ADG1414. FEATURES
i
CMOS, Serially-Controlled Octal SPST Switches Data Sheet ADG1414 FEATURES FUNCTIONAL BLOCK DIAGRAM SPI interface ADG1414 Supports daisy-chain mode S1 D1 9.5 Ω on resistance at 25°C and ±15 V dual supply S2 D2 1.6 Ω on-resistance flatness at 25°C and ±15 V dual supply S3 D3 Fully specified at ±15 V, +12 V, ±5 V S4 D4 S5 D5 3 V logic-compatible inputs S6 D6 Rail-to-rail operation S7 D7 24-lead TSSOP and 24-lead, 4 mm × 4 mm LFCSP S8 D8 APPLICATIONS INPUT SHIFT SDO REGISTER Automatic test equipment Data acquisition systems
01 0 7-
SCLK DIN SYNC RESET/V Battery-powered systems L
49 08
Sample-and-hold systems
Figure 1.
Audio signal routing Video signal routing Communication systems GENERAL DESCRIPTION
The ADG1414 is a monolithic complementary metal-oxide The ADG1414 uses a versatile 3-wire serial interface that semiconductor (CMOS) device containing eight independently operates at clock rates of up to 50 MHz and is compatible with selectable switches designed on an industrial CMOS (iCMOS®) standard SPI, QSPI™, MICROWIRE™, and DSP interface process. iCMOS is a modular manufacturing process combining standards. The output of the shift register, SDO, enables a high voltage CMOS and bipolar technologies. iCMOS components number of these devices to be daisy chained. can tolerate high supply voltages while providing increased perfor- At power-up, all switches are in the off condition, and the mance, dramatically lower power consumption, and reduce the internal registers contain all zeros. package size.
PRODUCT HIGHLIGHTS
The ADG1414 is a set of octal, single-pole, single-throw (SPST) switches controlled via a 3-wire serial interface. On resistance is 1. 50 MHz serial interface. matched closely between switches and is very flat over the full 2. 9.5 Ω on resistance. signal range. Each switch conducts equally well in both directions 3. 1.6 Ω on-resistance flatness. and the input signal range extends to the supplies. 4. 24-lead TSSOP and 4 mm × 4 mm LFCSP packages. Data is written to these devices in the form of eight bits; each bit corresponds to one channel.
Rev. B Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2009–2015 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications Functional Block Diagram Product Highlights Revision History Specifications ±15 V Dual Supply 12 V Single Supply ±5 V Dual Supply Continuous Current per Channel Timing Characteristics Timing Diagrams Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Test Circuits Terminology Theory of Operation Serial Interface Input Shift Register Power-On Reset Daisy Chaining Outline Dimensions Ordering Guide
