Datasheet ADG1419 (Analog Devices) - 10
Description2.1 Ω On Resistance, ±15 V/+12 V/±5 V, iCMOS SPDT Switch
Pages / Page16 / 10 — ADG1419. Data Sheet. DD = +15V. IDD PER CHANNEL. SS = –15V. BIAS = ±10V. …
File Format / SizePDF / 442 Kb
ADG1419. Data Sheet. DD = +15V. IDD PER CHANNEL. SS = –15V. BIAS = ±10V. A = 25°C. A) n (. ID (OFF) – +. RRE. ID (OFF) + –. ID, IS (ON) + +
ADG1419 Data Sheet DD = +15V IDD PER CHANNEL SS = –15V BIAS = ±10V A = 25°C A) n ( ID (OFF) – + RRE ID (OFF) + – ID, IS (ON) + +
ADG1419 Data Sheet 70 V 90 DD = +15V V IDD PER CHANNEL SS = –15V 60 V T BIAS = ±10V 80 A = 25°C 70 50 A) n ( 60 NT 40 ID (OFF) – + 50 ) RRE ID (OFF) + – A 30 ID, IS (ON) + + CU 40 VDD = +15V E IS (OFF) + – VDD = +12V I I DD VSS = –15V V 20 S (OFF) – + SS = 0V I 30 D, IS (ON) – – AKAG E 20 L 10 10 VDD = +5V V 0 SS = –5V 0 –10 –10
19
0 20 40 60 80 100 120
1 -0
0 2 4 6 8 10 12 14 16
-01 85
TEMPERATURE (°C)
84
LOGIC LEVEL, IN (V)
08485 0 Figure 11. Leakage Currents as a Function of Temperature, Figure 14. IDD vs. Logic Level ±15 V Dual Supply
70 500 VDD = 12V T V A = 25°C SS = 0V 400 60 V V BIAS = 1V/10V DD = +5V VSS = –5V 300 50 A) C) p 200 (n T N ( N 40 IO 100 I VDD = +12V D (OFF) – + T V V I C DD = +15V SS = 0V URRE 30 D (OFF) + – V I JE 0 SS = –15V C D, IS (ON) + + N E ID, IS (ON) – – I E –100 20 IS (OFF) + – IS (OFF) – + AKAG E –200 HARG L 10 C –300 0 –400 –10 –500 0 20 40 60 80 100 120
2 8
–5 –10 –15 0 5 10 15
03 00 5- 5-
TEMPERATURE (°C)
48
V
48
S (V)
08 08 Figure 12. Leakage Currents as a Function of Temperature, +12 V Single Supply Figure 15. Charge Injection vs. Source Voltage
60 500 VDD = +5V VSS = –5V V 450 50 BIAS = ±4.5V 400 ) A 40 350 (n VDD = +5V V NT SS = –5V ) 300 30 ID (OFF) – + I ns URRE D (OFF) + – ( I E 250 C S (OFF) + – M V E 20 IS (OFF) – + DD = +12V I TI VSS = 0V D,IS (ON) + + 200 ID,IS (ON) – – AKAG E 10 150 L 100 VDD = +15V 0 VSS = –15V 50 10 0 0 20 40 60 80 100 120
0
–40 –20 0 20 40 60 80 100 120
02 10 0 5- 5-
TEMPERATURE (°C)
48
TEMPERATURE (°C)
48 08 08 Figure 13. Leakage Currents as a Function of Temperature, ±5 V Dual Supply Figure 16. tTRANSITION Times vs. Temperature Rev. A | Page 10 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY +12 V SINGLE SUPPLY ±5 V DUAL SUPPLY CONTINUOUS CURRENT PER CHANNEL, S OR D ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
