Datasheet ADG1419 (Analog Devices) - 3
Description2.1 Ω On Resistance, ±15 V/+12 V/±5 V, iCMOS SPDT Switch
Pages / Page16 / 3 — Data Sheet. ADG1419. SPECIFICATIONS ±15 V DUAL SUPPLY. Table 1. …
File Format / SizePDF / 442 Kb
Data Sheet. ADG1419. SPECIFICATIONS ±15 V DUAL SUPPLY. Table 1. Parameter. 25°C. −40°C to +85°C. −40°C to +125°C. Unit
Data Sheet ADG1419 SPECIFICATIONS ±15 V DUAL SUPPLY Table 1 Parameter 25°C −40°C to +85°C −40°C to +125°C Unit
link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 13 link to page 13 link to page 13 link to page 13 link to page 13 link to page 13 link to page 4
VDD = +15 V ± 10%, VSS = −15 V ± 10%, GND = 0 V, unless otherwise noted.
Table 1. Parameter 25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range VDD to VSS V On Resistance, RON 2.1 Ω typ VS = ±10 V, IS = −10 mA; see Figure 22 2.4 2.8 3.2 Ω max VDD = +13.5 V, VSS = −13.5 V On-Resistance Match Between 0.05 Ω typ VS = ±10 V, IS = −10 mA Channels, ∆RON 0.2 0.25 0.3 Ω max On-Resistance Flatness, RFLAT (ON) 0.4 Ω typ VS = ±10 V, IS = −10 mA 0.5 0.6 0.65 Ω max LEAKAGE CURRENTS VDD = +16.5 V, VSS = −16.5 V Source Off Leakage, IS (Off ) ±0.1 nA typ VS = ±10 V, VS = ±10 V; see Figure 23 ±0.5 ±2 ±75 nA max Drain Off Leakage, ID (Off ) ±0.2 nA typ VS = ±10 V, VS = ±10 V; see Figure 23 ±0.6 ±3 ±100 nA max Channel On Leakage, ID, IS (On) ±0.2 nA typ VS = VD = ±10 V; see Figure 24 ±1 ±3 ±100 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH 0.005 μA typ VIN = VGND or VDD ±0.1 μA max Digital Input Capacitance, CIN 4 pF typ DYNAMIC CHARACTERISTICS1 Transition Time, tTRANSITION 130 ns typ RL = 300 Ω, CL = 35 pF 155 190 220 ns max VS = +10 V; see Figure 25 tON (EN) 85 ns typ RL = 300 Ω, CL = 35 pF 110 125 140 ns max VS = 10 V; see Figure 27 tOFF (EN) 115 ns typ RL = 300 Ω, CL = 35 pF 140 160 180 ns max VS = 10 V; see Figure 27 Break-Before-Make Time Delay, tD 15 ns typ RL = 300 Ω, CL = 35 pF 8 ns min VS1 = VS2 = 10 V; see Figure 26 Charge Injection −16 pC typ VS = 0 V, RS = 0 Ω, CL = 1 nF; see Figure 28 Off Isolation −64 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 29 Channel-to-Channel Crosstalk −64 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 30 Total Harmonic Distortion Plus Noise 0.016 % typ RL = 10 kΩ, 5 V rms, f = 20 Hz to (THD + N) 20 kHz; see Figure 32 −3 dB Bandwidth 135 MHz typ RL = 50 Ω, CL = 5 pF; see Figure 31 Insertion Loss 0.16 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 31 CS (Off ) 19 pF typ f = 1 MHz; VS = 0 V CD (Off ) 44 pF typ f = 1 MHz; VS = 0 V CD, CS (On) 114 pF typ f = 1 MHz; VS = 0 V Rev. A | Page 3 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY +12 V SINGLE SUPPLY ±5 V DUAL SUPPLY CONTINUOUS CURRENT PER CHANNEL, S OR D ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
