Datasheet ADG1419 (Analog Devices) - 4
Description2.1 Ω On Resistance, ±15 V/+12 V/±5 V, iCMOS SPDT Switch
Pages / Page16 / 4 — ADG1419. Data Sheet. Parameter. 25°C. −40°C to +85°C. −40°C to +125°C. …
File Format / SizePDF / 442 Kb
ADG1419. Data Sheet. Parameter. 25°C. −40°C to +85°C. −40°C to +125°C. Unit. Test Conditions/Comments. +12 V SINGLE SUPPLY
ADG1419 Data Sheet Parameter 25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments +12 V SINGLE SUPPLY
link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 13 link to page 13 link to page 5
POWER REQUIREMENTS VDD = +16.5 V, VSS = −16.5 V IDD 0.002 μA typ Digital inputs = 0 V or VDD 1.0 μA max IDD, 8-Lead MSOP 58 μA typ Digital inputs = 5 V 95 μA max IDD, 8-Lead LFCSP 120 μA typ Digital inputs = 5 V 190 μA max ISS 0.002 μA typ Digital inputs = 0 V, 5 V, or VDD 1.0 μA max VDD/VSS ±4.5/±16.5 V min/max Ground = 0 V 1 Guaranteed by design, not subject to production test.
+12 V SINGLE SUPPLY
VDD = 12 V ± 10%, VSS = 0 V, GND = 0 V, unless otherwise noted.
Table 2. Parameter 25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 V to VDD V On Resistance, RON 4 Ω typ VS = 0 V to 10 V, IS = −10 mA; see Figure 22 4.6 5.5 6.2 Ω max VDD = +10.8 V, VSS = 0 V On-Resistance Match Between 0.08 Ω typ VS = 0 V to 10 V, IS = −10 mA Channels, ∆RON 0.25 0.3 0.35 Ω max On-Resistance Flatness, RFLAT (ON) 1.2 Ω typ VS = 0 V to 10 V, IS = −10 mA 1.5 1.75 1.9 Ω max LEAKAGE CURRENTS VDD = +13.2 V, VSS = 0 V Source Off Leakage, IS (Off ) ±0.1 nA typ VS = 1 V/10 V, VD = 10 V/1 V; see Figure 23 ±0.5 ±2 ±75 nA max Drain Off Leakage, ID (Off ) ±0.2 nA typ VS = 1 V/10 V, VD = 10 V/1 V; see Figure 23 ±0.6 ±3 ±100 nA max Channel On Leakage, ID, IS (On) ±0.2 nA typ VS = VD = 1 V or 10 V; see Figure 24 ±1 ±3 ±100 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH 0.005 μA typ VIN = VGND or VDD ±0.1 μA max Digital Input Capacitance, CIN 4 pF typ DYNAMIC CHARACTERISTICS1 Transition Time, tTRANSITION 200 ns typ RL = 300 Ω, CL = 35 pF 255 265 370 ns max VS = 8 V; see Figure 25 tON (EN) 145 ns typ RL = 300 Ω, CL = 35 pF 190 220 245 ns max VS = 8 V; see Figure 27 tOFF (EN) 130 ns typ RL = 300 Ω, CL = 35 pF 170 205 220 ns max VS = 8 V; see Figure 27 Break-Before-Make Time Delay, tD 55 ns typ RL = 300 Ω, CL = 35 pF 33 ns min VS1 = VS2 = 8 V; see Figure 26 Charge Injection 13 pC typ VS = 6 V, RS = 0 Ω, CL = 1 nF; see Figure 28 Off Isolation −60 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 29 Rev. A | Page 4 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY +12 V SINGLE SUPPLY ±5 V DUAL SUPPLY CONTINUOUS CURRENT PER CHANNEL, S OR D ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
