Datasheet ADG1421, ADG1422, ADG1423 (Analog Devices) - 5
Description2.1 Ω On Resistance, ±15 V/+12 V/±5 V iCMOS Dual SPST Switches
Pages / Page16 / 5 — Data Sheet. ADG1421/ADG1422/ADG1423. ±5 V DUAL SUPPLY. Table 3. −40°C to. …
RevisionA
File Format / SizePDF / 497 Kb
Data Sheet. ADG1421/ADG1422/ADG1423. ±5 V DUAL SUPPLY. Table 3. −40°C to. Parameter 25°C. +85°C. +125°C. Unit Test. Conditions/Comments
Data Sheet ADG1421/ADG1422/ADG1423 ±5 V DUAL SUPPLY Table 3 −40°C to Parameter 25°C +85°C +125°C Unit Test Conditions/Comments
link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 13 link to page 13 link to page 13 link to page 13 link to page 13
VDD = +5 V ± 10%, VSS = −5 V ± 10%, GND = 0 V, unless otherwise noted.
Table 3. −40°C to −40°C to Parameter 25°C +85°C +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range VDD to VSS V On Resistance, RON 4.5 Ω typ VS = ±4.5 V, IS = −10 mA; see Figure 23 5.2 6.2 7 Ω max VDD = +4.5 V, VSS = −4.5 V On Resistance Match Between Channels, ∆RON 0.04 Ω typ VS = ±4.5V; IS = −10 mA 0.18 0.2 0.21 Ω max On Resistance Flatness, RFLAT (ON) 1.3 Ω typ VS = ±4.5 V, IS = −10 mA 1.6 1.85 2 Ω max LEAKAGE CURRENTS VDD = +5.5 V, VSS = −5.5 V Source Off Leakage, IS (Off) ±0.05 nA typ VS = ±4.5 V, VD = ∓4.5 V; see Figure 24 ±0.5 ±2 ±75 nA max Drain Off Leakage, ID (Off) ±0.05 nA typ VS = ±4.5 V, VD = ∓4.5 V; see Figure 24 ±0.5 ±2 ±75 nA max Channel On Leakage, ID, IS (On) ±0.1 nA typ VS = VD = ±4.5 V; see Figure 25 ±1 ±2 ±75 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH 0.005 μA typ VIN = VGND or VDD ±0.1 μA max Digital Input Capacitance, CIN 4 pF typ DYNAMIC CHARACTERISTICS1 tON 285 ns typ RL = 300 Ω, CL = 35 pF 370 460 520 ns max VS = 3 V; see Figure 26 tOFF 220 ns typ RL = 300 Ω, CL = 35 pF 295 350 395 ns max VS = 3 V; see Figure 26 Break-Before-Make Time Delay, tD (ADG1423 Only) 85 ns typ RL = 300 Ω, CL = 35 pF 45 ns min VS1 = VS2 = 3 V; see Figure 27 Charge Injection 82 pC typ VS = 0 V, RS = 0 Ω, CL = 1 nF; see Figure 28 Off Isolation −60 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 29 Channel-to-Channel Crosstalk −70 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 30 Total Harmonic Distortion + Noise 0.04 % typ RL = 10 kΩ, 5 V p-p, f = 20 Hz to 20 kHz; see Figure 32 −3 dB Bandwidth 150 MHz typ RL = 50 Ω, CL = 5 pF; see Figure 31 Insertion Loss 0.25 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 31 CS (Off) 25 pF typ VS = 0V, f = 1 MHz CD (Off) 30 pF typ VS = 0V, f = 1 MHz CD, CS (On) 100 pF typ VS = 0V, f = 1 MHz POWER REQUIREMENTS VDD = 5.5 V, VSS = −5.5 V IDD 0.001 μA typ Digital inputs = 0 V or VDD 1.0 μA max ISS 0.001 μA typ Digital inputs = 0 V or VDD 1.0 μA max VDD/VSS ±4.5/±16.5 V min/max Ground = 0 V 1 Guaranteed by design, not subject to production test. Rev. A | Page 5 of 16 Document Outline Features Applications General Description Functional Block Diagram Product Highlights Table of Contents Revision History Specifications ±15 V Dual Supply +12 V Single Supply ±5 V Dual Supply Continuous Current per Channel, S or D Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Test Circuits Terminology Outline Dimensions Ordering Guide
