Datasheet ADG1421, ADG1422, ADG1423 (Analog Devices) - 10
Description | 2.1 Ω On Resistance, ±15 V/+12 V/±5 V iCMOS Dual SPST Switches |
Pages / Page | 16 / 10 — ADG1421/ADG1422/ADG1423. Data Sheet. VDD = +15V. IDD PER CHANNEL. VSS = … |
Revision | A |
File Format / Size | PDF / 497 Kb |
ADG1421/ADG1422/ADG1423. Data Sheet. VDD = +15V. IDD PER CHANNEL. VSS = –15V. A = 25°C. BIAS = ±10V. A) n (. D (OFF) – +. CURRE. DD = +15V
ADG1421/ADG1422/ADG1423 Data Sheet 25 90 VDD = +15V IDD PER CHANNEL VSS = –15V 80 T V A = 25°C BIAS = ±10V 20 70 A) n ( 60 15 NT 50 A) 10 µ I ( 40 D (OFF) – + V CURRE DD = +15V V E I DD = +12V V S (OFF) + – I DD SS = –15V V I 30 SS = 0V S (OFF) – + 5 ID (OFF) + – AKAG I E D, IS (ON) + + 20 L ID, IS (ON) – – 10 VDD = +5V 0 VSS = –5V 0 –5 –10 0 20 40 60 80 100 120
014
0 2 4 6 8 10 12 14 16
013
TEMPERATURE (°C) LOGIC LEVEL, IN (V)
08487- 08487- Figure 12. Leakage Currents as a Function of Temperature, Figure 15. IDD vs. Logic Level ±15 V Dual Supply
25 500 VDD = 12V TA = 25°C VSS = 0V 400 VDD = +5V VBIAS = 1V/10V V 20 SS = –5V 300 A) C) n p 200 VDD = +15V ( 15 V N ( SS = –15V V NT DD = +12V IO 100 VSS = 0V IS (OFF) + – CT 10 ID (OFF) – + 0 CURRE I NJE E D (OFF) + – I IS (OFF) – + E –100 ID, IS (ON) + + 5 AKAG ID, IS (ON) – – –200 E L CHARG –300 0 –400 –5 –500
015
0 20 40 60 80 100 120 –15 –10 –5 0 5 10 15
034 08487-
TEMPERATURE (°C) VS (V)
08487- Figure 13. Leakage Currents as a Function of Temperature, +12 V Single Supply Figure 16. Charge Injection vs. Source Voltage
25 350 VDD = +5V VSS = –5V VBIAS = ±4.5V 20 300 A) n 250 ( 15 t NT OFF (±5V) ) s 200 10 IS (OFF) + – CURRE I tON (±5V) E D (OFF) – + IME (n T 150 IS (OFF) – + I 5 D (OFF) + – AKAG ID, IS (ON) + + E 100 L ID, IS (ON) – – tON (+12V) 0 tOFF (+12V) 50 tOFF (±15V) tON (±15V) –5 0 0 20 40 60 80 100 120 –40 –20 0 20 40 60 80 100 120
016 006
TEMPERATURE( °C) TEMPERATURE (°C)
08487- 08487- Figure 14. Leakage Currents as a Function of Temperature, ±5 V Dual Supply Figure 17. tTRANSITION Times vs. Temperature Rev. A | Page 10 of 16 Document Outline Features Applications General Description Functional Block Diagram Product Highlights Table of Contents Revision History Specifications ±15 V Dual Supply +12 V Single Supply ±5 V Dual Supply Continuous Current per Channel, S or D Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Test Circuits Terminology Outline Dimensions Ordering Guide
