Datasheet ADG1421, ADG1422, ADG1423 (Analog Devices) - 3
Description2.1 Ω On Resistance, ±15 V/+12 V/±5 V iCMOS Dual SPST Switches
Pages / Page16 / 3 — Data Sheet. ADG1421/ADG1422/ADG1423. SPECIFICATIONS ±15 V DUAL SUPPLY. …
File Format / SizePDF / 497 Kb
Data Sheet. ADG1421/ADG1422/ADG1423. SPECIFICATIONS ±15 V DUAL SUPPLY. Table 1. −40°C to. Parameter 25°C. +85°C. +105°C. +125°C
Data Sheet ADG1421/ADG1422/ADG1423 SPECIFICATIONS ±15 V DUAL SUPPLY Table 1 −40°C to Parameter 25°C +85°C +105°C +125°C
link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 13 link to page 13 link to page 13 link to page 13 link to page 13
VDD = +15 V ± 10%, VSS = −15 V ± 10%, GND = 0 V, unless otherwise noted.
Table 1. −40°C to −40°C to −40°C to Parameter 25°C +85°C +105°C +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range VDD to VSS V On Resistance, RON 2.1 Ω typ VS = ±10 V, IS = −10 mA; see Figure 23 2.4 2.8 2.95 3.2 Ω max VDD = +13.5 V, VSS = −13.5 V On Resistance Match Between Channels, ∆RON 0.02 Ω typ VS = ±10 V, IS = −10 mA 0.1 0.12 0.124 0.13 Ω max On Resistance Flatness, RFLAT (ON) 0.4 Ω typ VS = ±10 V, IS = −10 mA 0.5 0.6 0.63 0.65 Ω max LEAKAGE CURRENTS VDD = +16.5 V, VSS = −16.5 V Source Off Leakage, IS (Off) ±0.1 nA typ VS = ±10 V, VD = ±10 V; see Figure 24 ±0.5 ±2 ±9 ±75 nA max Drain Off Leakage, ID (Off) ±0.1 nA typ VS = ±10 V, VD = ±10 V; see Figure 24 ±0.5 ±2 ±9 ±75 nA max Channel On Leakage, ID, IS (On) ±0.2 nA typ VS = VD = ±10 V; see Figure 25 ±1 ±2 ±9 ±75 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH 0.005 μA typ VIN = VGND or VDD ±0.1 μA max Digital Input Capacitance, CIN 4 pF typ DYNAMIC CHARACTERISTICS1 tON 115 ns typ RL = 300 Ω, CL = 35 pF 145 180 210 ns max VS = 10 V; see Figure 26 tOFF 115 ns typ RL = 300 Ω, CL = 35 pF 145 165 190 ns max VS = 10 V; see Figure 26 Break-Before-Make Time Delay, tD (ADG1423 Only) 45 ns typ RL = 300 Ω, CL = 35 pF 30 ns min VS1 = VS2 = 10 V; see Figure 27 Charge Injection −5 pC typ VS = 0 V, RS = 0 Ω, CL = 1 nF; see Figure 28 Off Isolation −64 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 29 Channel-to-Channel Crosstalk −74 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 30 Total Harmonic Distortion + Noise 0.016 % typ RL = 10 kΩ, 5 V rms, f = 20 Hz to 20 kHz; see Figure 32 −3 dB Bandwidth 180 MHz typ RL = 50 Ω, CL = 5 pF; see Figure 31 Insertion Loss 0.12 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 31 CS (Off) 18 pF typ f = 1 MHz; VS = 0 V CD (Off) 22 pF typ f = 1 MHz; VS = 0 V CD, CS (On) 86 pF typ f = 1 MHz; VS = 0 V POWER REQUIREMENTS VDD = +16.5 V, VSS = −16.5 V IDD 0.002 μA typ Digital inputs = 0 V or VDD 1.0 μA max IDD 120 μA typ Digital inputs = 5 V 190 μA max ISS 0.002 μA typ Digital inputs = 0 V, 5 V, or VDD 1.0 μA max VDD/VSS ±4.5/±16.5 V min/max Ground = 0 V 1 Guaranteed by design, not subject to production test. Rev. A | Page 3 of 16 Document Outline Features Applications General Description Functional Block Diagram Product Highlights Table of Contents Revision History Specifications ±15 V Dual Supply +12 V Single Supply ±5 V Dual Supply Continuous Current per Channel, S or D Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Test Circuits Terminology Outline Dimensions Ordering Guide
