Datasheet ADG1404 (Analog Devices) - 3
Description1.5 Ω On Resistance, ±15 V/12 V/±5 V, 4:1, iCMOS Multiplexer
Pages / Page16 / 3 — Data Sheet. ADG1404. SPECIFICATIONS 15 V DUAL SUPPLY. Table 1. Parameter. …
RevisionB
File Format / SizePDF / 469 Kb
Data Sheet. ADG1404. SPECIFICATIONS 15 V DUAL SUPPLY. Table 1. Parameter. 25°C. −40°C to +85°C. −40°C to +125°C. Unit
Data Sheet ADG1404 SPECIFICATIONS 15 V DUAL SUPPLY Table 1 Parameter 25°C −40°C to +85°C −40°C to +125°C Unit
link to page 13 link to page 13 link to page 13 link to page 13 link to page 14 link to page 15 link to page 15 link to page 14 link to page 15 link to page 13 link to page 13 link to page 14 link to page 13 link to page 13
VDD = 15 V ± 10%, VSS = −15 V± 10%, GND = 0 V, unless otherwise noted.
Table 1. Parameter 25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range VDD to VSS V On Resistance (RON) 1.5 Ω typ VS = ±10 V, IS = −10 mA; see Figure 22 1.8 2.3 2.6 Ω max VDD = +13.5 V, VSS = −13.5 V On-Resistance Match 0.1 Ω typ VS = ±10 V, IS = −10 mA Between Channels (ΔRON) 0.18 0.19 0.21 Ω max On-Resistance Flatness (RFLAT(ON)) 0.3 Ω typ VS = ±10 V, IS = −10 mA 0.36 0.4 0.45 Ω max LEAKAGE CURRENTS VDD = +16.5 V, VSS = −16.5 V Source Off Leakage, IS (Off) ±0.03 nA typ VS = ±10 V, Vs = ∓10 V; see Figure 23 ±0.55 ±2 ±12.5 nA max Drain Off Leakage, ID (Off) ±0.04 nA typ VS = ±10 V, Vs = ∓10 V; see Figure 23 ±0.55 ±4 ±30 nA max Channel On Leakage, ID, IS (On) ±0.1 nA typ VS = VD = ±10 V; see Figure 24 ±2 ±4 ±30 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINLor INH 0.005 µA typ VIN = VGND or VDD ±0.1 µA max Digital Input Capacitance, CIN 3.5 pF typ DYNAMIC CHARACTERISTICS1 Transition Time, tTRANSITION 150 ns typ RL = 300 Ω, CL = 35 pF 180 220 250 ns max VS = +10 V; see Figure 29 tON (EN) 100 ns typ RL = 300 Ω, CL = 35 pF 120 145 165 ns max VS = +10 V; see Figure 31 tOFF (EN) 110 ns typ RL = 300 Ω, CL = 35 pF 135 165 185 ns max VS = +10 V; see Figure 31 Break-Before-Make Time Delay, tBBM 35 ns typ RL = 300 Ω, CL = 35 pF 10 ns min VS1 = VS2 = 10 V; see Figure 30 Charge Injection −20 pC typ VS = 0 V, RS = 0 Ω, CL = 1 nF; see Figure 32 Off Isolation 70 dB typ RL = 50 Ω, CL = 5 pF, f = 100 kHz; see Figure 25 Channel-to-Channel Crosstalk 82 dB typ RL = 50 Ω, CL = 5 pF, f = 100 kHz; see Figure 27 Total Harmonic Distortion + Noise 0.011 % typ RL = 110 Ω, 10 V p-p, f = 20 Hz to 20 kHz; see Figure 28 −3 dB Bandwidth 55 MHz typ RL = 50 Ω, CL = 5 pF; see Figure 26 Insertion Loss −0.17 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 26 CS (Off) 23 pF typ f = 1 MHz, VS = 0 V CD (Off) 90 pF typ f = 1 MHz, VS = 0 V CD, CS (On) 170 pF typ f = 1 MHz, VS = 0 V POWER REQUIREMENTS VDD = +16.5 V, VSS = −16.5 V IDD 0.001 µA typ Digital inputs = 0 V or VDD 1 µA max IDD 170 µA typ Digital inputs = 5 V 285 µA max ISS 0.001 µA typ Digital inputs = 0 V or VDD 1 µA max VDD/VSS ±4.5/±16.5 V min/max GND = 0 V 1 Guaranteed by design, not subject to production test. Rev. B | Page 3 of 16 Document Outline Features Applications Functional Block Diagram General Description Product Highlights Revision History Specifications 15 V Dual Supply 12 V Single Supply 5 V Dual Supply Continuous Current, S or D Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Truth Table Typical Performance Characteristics Terminology Test Circuits Outline Dimensions Ordering Guide
