Datasheet ADG1404 (Analog Devices) - 10
Description | 1.5 Ω On Resistance, ±15 V/12 V/±5 V, 4:1, iCMOS Multiplexer |
Pages / Page | 16 / 10 — ADG1404. Data Sheet. TA = 25°C. IDD PER LOGIC INPUT. IS (OFF) + –. ID … |
Revision | B |
File Format / Size | PDF / 469 Kb |
ADG1404. Data Sheet. TA = 25°C. IDD PER LOGIC INPUT. IS (OFF) + –. ID (OFF) + –. S (OFF) – +. ID (OFF) – +. VDD = +15V. AKAG. I DD
ADG1404 Data Sheet 6 80 TA = 25°C 4 IDD PER LOGIC INPUT 70 2 60 0 A) IS (OFF) + – 50 n –2 ( ID (OFF) + – E A) I µ –4 S (OFF) – + ( 40 ID (OFF) – + VDD = +15V AKAG I I DD –6 D, IS (ON) + + V E SS = –15V V L I 30 DD = +12V D, IS (ON) – – VSS = 0V –8 20 –10 VDD = +15V 10 –12 V V DD = +5V SS = –15V V V SS = –5V BIAS = +10V/–10V –14 0 0 20 40 60 80 100 120
111
0 2 4 6 8 10 12 14
008
TEMPERATURE (°C) LOGIC, Ax (V)
06816- 06815- Figure 10. Leakage Currents as a Function of Temperature,15 V Dual Supply Figure 13. IDD vs. Logic Level
4 600 IS (OFF) + – TA = 25°C ID (OFF) + – 3 IS (OFF) – + 400 ID (OFF) – + V 2 I DD = +15V, VSS = –15V D, IS (ON) + + C) ID, IS (ON) – – p 200 N ( A) 1 n IO V ( DD = +5V, VSS = –5V E CT 0 0 NJE AKAG I V E E DD = +12V, VSS = 0V –1 L –200 –2 CHARG –400 –3 VDD = +5V VSS = –5V VBIAS = +4.5V/–4.5V –4 –600 0 20 40 60 80 100 120
112
–15 –10 –5 0 5 10 15
012
TEMPERATURE (°C) V
06816-
S (V)
06816- Figure 11. Leakage Currents as a Function of Temperature, 5 V Dual Supply Figure 14. Charge Injection vs. Source Voltage
14 500 IS (OFF) + – 12 ID (OFF) + – 450 IS (OFF) – + VDD = +5V, VSS = –5V I 400 10 D (OFF) – + ID, IS (ON) + + I 350 8 D, IS (ON) – – A) n ) 300 ( 6 s E VDD = +12V, VSS = 0V 250 4 IME (n AKAG T E 200 L 2 150 VDD = +15V, VSS = –15V 0 100 V –2 DD = 12V V 50 SS = 0V VBIAS = 1V/10V –4 0 0 20 40 60 80 100 120
113
–40 –20 0 20 40 60 80 100 120
013
TEMPERATURE (°C) TEMPERATURE (°C)
06816- 06816- Figure 12. Leakage Currents as a Function of Temperature, 12 V Single Supply Figure 15. Transition Times vs. Temperature Rev. B | Page 10 of 16 Document Outline Features Applications Functional Block Diagram General Description Product Highlights Revision History Specifications 15 V Dual Supply 12 V Single Supply 5 V Dual Supply Continuous Current, S or D Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Truth Table Typical Performance Characteristics Terminology Test Circuits Outline Dimensions Ordering Guide
