Datasheet ADG1404 (Analog Devices) - 7
Description1.5 Ω On Resistance, ±15 V/12 V/±5 V, 4:1, iCMOS Multiplexer
Pages / Page16 / 7 — Data Sheet. ADG1404. ABSOLUTE MAXIMUM RATINGS. Table 5. Parameter. …
RevisionB
File Format / SizePDF / 469 Kb
Data Sheet. ADG1404. ABSOLUTE MAXIMUM RATINGS. Table 5. Parameter. Rating. ESD CAUTION
Data Sheet ADG1404 ABSOLUTE MAXIMUM RATINGS Table 5 Parameter Rating ESD CAUTION
link to page 6
TA = 25°C, unless otherwise noted. Stresses at or above those listed under Absolute Maximum
Table 5.
Ratings may cause permanent damage to the product. This is a
Parameter Rating
stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational VDD to VSS 35 V section of this specification is not implied. Operation beyond VDD to GND −0.3 V to +25 V the maximum operating conditions for extended periods may VSS to GND +0.3 V to −25 V affect product reliability. Analog Inputs1 VSS − 0.3 V to VDD + 0.3 V or 30 mA, whichever occurs first Only one absolute maximum rating can be applied at any Digital Inputs GND − 0.3 V to VDD + 0.3 V or one time. 30 mA, whichever occurs first
ESD CAUTION
Peak Current, S or D 600 mA (pulsed at 1 ms, 10% duty cycle maximum) Continuous Current, S or D2 Data + 15% Operating Temperature Range Automotive (Y Version) −40°C to +125°C Storage Temperature Range −65°C to +150°C Junction Temperature 150°C 14-Lead TSSOP, θ JA Thermal 112°C/W Impedance (4-layer board) 16-Lead LFCSP, θJA Thermal 30.4°C/W Impedance Reflow Soldering Peak 260(+0/−5)°C Temperature, Pb free 1 Overvoltages at IN, S, and D are clamped by internal diodes. Current must be limited to the maximum ratings given. 2 See data given in Table 4. Rev. B | Page 7 of 16 Document Outline Features Applications Functional Block Diagram General Description Product Highlights Revision History Specifications 15 V Dual Supply 12 V Single Supply 5 V Dual Supply Continuous Current, S or D Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Truth Table Typical Performance Characteristics Terminology Test Circuits Outline Dimensions Ordering Guide
