Datasheet ADG1411, ADG1412, ADG1413 (Analog Devices) - 3
Description1.5 Ω On Resistance, ±15 V/+12 V/±5 V, iCMOS, Quad SPST Switches
Pages / Page16 / 3 — Data Sheet. ADG1411/ADG1412/ADG1413. SPECIFICATIONS ±15 V DUAL SUPPLY. …
RevisionD
File Format / SizePDF / 410 Kb
Data Sheet. ADG1411/ADG1412/ADG1413. SPECIFICATIONS ±15 V DUAL SUPPLY. Table 1. Parameter. 25°C. −40°C to +85°C. −40°C to +125°C
Data Sheet ADG1411/ADG1412/ADG1413 SPECIFICATIONS ±15 V DUAL SUPPLY Table 1 Parameter 25°C −40°C to +85°C −40°C to +125°C
link to page 13 link to page 13 link to page 13 link to page 13 link to page 14 link to page 14 link to page 14 link to page 14 link to page 13 link to page 13 link to page 14 link to page 13 link to page 13
VDD = 15 V ± 10%, VSS = −15 V ± 10%, GND = 0 V, unless otherwise noted.
Table 1. Parameter 25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range VDD to VSS V On Resistance, RON 1.5 Ω typ VS = ±10 V, IS = −10 mA; see Figure 23 1.8 2.3 2.6 Ω max VDD = +13.5 V, VSS = −13.5 V On-Resistance Match Between 0.1 Ω typ VS = ±10 V , IS = −10 mA Channels, ∆RON 0.18 0.19 0.21 Ω max On-Resistance Flatness, RFLAT(ON) 0.3 Ω typ VS = ±10 V, IS = −10 mA 0.36 0.4 0.45 Ω max LEAKAGE CURRENTS VDD = +16.5 V, VSS = −16.5 V Source Off Leakage, IS (Off) ±0.03 nA typ VS = ±10 V, VD = ∓10 V; see Figure 24 ±0.55 ±2 ±12.5 nA max ADG1411WBCPZ-REEL Only ±3 ±40 nA max Drain Off Leakage, ID (Off) ±0.03 nA typ VS = ±10 V, VD = ∓10 V; see Figure 24 ±0.55 ±2 ±12.5 nA max ADG1411WBCPZ-REEL Only ±3 ±40 nA max Channel On Leakage, ID, IS (On) ±0.15 nA typ VS = VD = ±10 V; see Figure 25 ±2 ±4 ±30 nA max ADG1411WBCPZ-REEL Only ±3 ±40 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH 0.005 µA typ VIN = VGND or VDD ±0.1 µA max Digital Input Capacitance, CIN 3.5 pF typ DYNAMIC CHARACTERISTICS1 tON 100 ns typ RL = 300 Ω, CL = 35 pF 150 170 190 ns max VS = 10 V; see Figure 30 tOFF 90 ns typ RL = 300 Ω, CL = 35 pF 120 140 160 ns max VS = 10 V; see Figure 30 Break-Before-Make Time Delay, tD 25 ns typ RL = 300 Ω, CL = 35 pF (ADG1413 Only) 10 ns min VS1 = VS2 = 10 V; see Figure 31 Charge Injection, QINJ −20 pC typ VS = 0 V, RS = 0 Ω, CL = 1 nF; see Figure 32 Off Isolation −80 dB typ RL = 50 Ω, CL = 5 pF, f = 100 kHz; see Figure 26 Channel-to-Channel Crosstalk −100 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 27 Total Harmonic Distortion + Noise 0.014 % typ RL = 110 Ω, 15 V p-p, f = 20 Hz to 20 kHz; see Figure 29 −3 dB Bandwidth 170 MHz typ RL = 50 Ω, CL = 5 pF; see Figure 28 Insertion Loss −0.35 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 28 CS (Off) 23 pF typ VS = 0 V, f = 1 MHz CD (Off) 23 pF typ VS = 0 V, f = 1 MHz CD, CS (On) 116 pF typ VS = 0 V, f = 1 MHz POWER REQUIREMENTS VDD = +16.5 V, VSS = −16.5 V IDD 0.001 µA typ Digital inputs = 0 V or VDD 1 µA max IDD 220 µA typ Digital inputs = 5 V 380 µA max ISS 0.001 µA typ Digital inputs = 0 V or VDD 1 µA max VDD/VSS ±4.5/±16.5 V min/V max GND = 0 V 1 Guaranteed by design; not subject to production test. Rev. D | Page 3 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY +12 V SINGLE SUPPLY ±5 V DUAL SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
