Datasheet ADG1411, ADG1412, ADG1413 (Analog Devices) - 10
Description | 1.5 Ω On Resistance, ±15 V/+12 V/±5 V, iCMOS, Quad SPST Switches |
Pages / Page | 16 / 10 — ADG1411/ADG1412/ADG1413. Data Sheet. 300. VDD = +15V V. –0.5. SS = –15V. … |
Revision | D |
File Format / Size | PDF / 410 Kb |
ADG1411/ADG1412/ADG1413. Data Sheet. 300. VDD = +15V V. –0.5. SS = –15V. 250. A = 25°C. 12V SS tON. –1.0. 200. dB (. –1.5. ) s. 15V DS tON. 150. LOS
ADG1411/ADG1412/ADG1413 Data Sheet 300 0 VDD = +15V V –0.5 SS = –15V T 250 A = 25°C 12V SS tON –1.0 ) 200 dB ( –1.5 S ) s 15V DS tON 150 LOS –2.0 IME (n T TION R –2.5 E 100 S 15V DS t IN 12V SS t OFF OFF –3.0 50 –3.5 0 –4.0 –40 –20 0 20 40 60 80 100 120
013
10k 100k 1M 10M 100M 1G
016
TEMPERATURE (°C) FREQUENCY (Hz)
06815- 06815- Figure 16. tON/tOFF Times vs. Temperature for Figure 19. On Response vs. Frequency, Single Supply (SS) and Dual Supply (DS) ±15 V Dual Supply
0 0 VDD = +15V VDD = +15V –10 VSS = –15V –10 VSS = –15V TA = 25°C V p-p = 0.62V –20 –20 TA = 25°C ) –30 –30 dB ( –40 B) –40 d NO DECOUPLING CAPACITORS TION –50 –50 RR ( S OLA –60 –60 DECOUPLING ACP CAPACITORS OFF IS –70 –70 ON SUPPLIES –80 –80 –90 –90 –100 –100 1k 10k 100k 1M 10M 100M 1G
014
1k 10k 100k 1M 10M
017
FREQUENCY (Hz) FREQUENCY (Hz)
06815- 06815- Figure 17. Off Isolation vs. Frequency, Figure 20. ACPSRR vs. Frequency, ±15 V Dual Supply ±15 V Dual Supply
0 0.028 VDD = +15V –10 0.026 V V S = 20V p-p SS = –15V T –20 A = 25°C 0.024 VDD = +15V V 0.022 SS = –15V –30 TA = 25°C 0.020 –40 B) d 0.018 –50 %) K ( 0.016 AL –60 N ( T VS = 15V p-p S 0.014 S –70 HD + T 0.012 CRO –80 0.010 –90 0.008 VS = 10V p-p –100 0.006 –110 0.004 –120 0.002 10k 100k 1M 10M 100M 1G
015
10 100 1k 10k 100k
117
06815- 06815- Figure 18. Crosstalk vs. Frequency, Figure 21. THD + N vs. Frequency, ±15 V Dual Supply ±15 V Dual Supply Rev. D | Page 10 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY +12 V SINGLE SUPPLY ±5 V DUAL SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
