Datasheet ADG1411, ADG1412, ADG1413 (Analog Devices) - 9
Description1.5 Ω On Resistance, ±15 V/+12 V/±5 V, iCMOS, Quad SPST Switches
Pages / Page16 / 9 — Data Sheet. ADG1411/ADG1412/ADG1413. 5.0. DD = 12V. S (OFF) + –. 4.5. VSS …
RevisionD
File Format / SizePDF / 410 Kb
Data Sheet. ADG1411/ADG1412/ADG1413. 5.0. DD = 12V. S (OFF) + –. 4.5. VSS = 0V. ID (OFF) + –. VBIAS = 1V/10V. IS (OFF) – +. 4.0. A = 125°C
Data Sheet ADG1411/ADG1412/ADG1413 5.0 DD = 12V S (OFF) + – 4.5 VSS = 0V ID (OFF) + – VBIAS = 1V/10V IS (OFF) – + 4.0 A = 125°C
Data Sheet ADG1411/ADG1412/ADG1413 5.0 9 V I DD = 12V S (OFF) + – 4.5 8 VSS = 0V ID (OFF) + – VBIAS = 1V/10V T IS (OFF) – + 4.0 A = 125°C I 7 I S = 100mA D (OFF) – + ) ID, IS (ON) ++ 3.5 6 (Ω ID, IS (ON) – – A) 3.0 n 5 ( E 2.5 4 T SISTANCE A = 25°C I 2.0 S = 190mA AKAG RE 3 E N L O 1.5 2 1.0 1 0.5 V 0 DD = +5V VSS = –5V 0 –1 –5 –4 –3 –2 –1 0 1 2 3 4 5
010
0 20 40 60 80 100 120
007
VS OR VD (V) TEMPERATURE (°C)
06815- 06815- Figure 10. On Resistance vs. VD or VS for Different Current Levels, Figure 13. Leakage Currents vs. Temperature, ±5 V Dual Supply +12 V Single Supply
1.5 80 I TA = 25°C D, IS (ON) + + I 1.0 DD PER LOGIC INPUT 70 I I D (OFF) – + S (OFF) + – 0.5 60 0 A) 50 n –0.5 ( E A) µ –1.0 ( 40 ID, IS (ON) – – V I DD DD = +15V AKAG –1.5 V E SS = –15V VDD = +12V L 30 ID (OFF) + – VSS = 0V –2.0 20 –2.5 V I DD = +15V S (OFF) – + 10 –3.0 V V DD = +5V SS = –15V V V SS = –5V BIAS = +10V/–10V –3.5 0 0 20 40 60 80 100 120
005
0 2 4 6 8 10 12 14
008
TEMPERATURE (°C) LOGIC, INx (V)
06815- 06815- Figure 11. Leakage Currents vs. Temperature, Figure 14. IDD vs. Logic Level ±15 V Dual Supply
1.5 600 VDD = +5V TA = 25°C VSS = –5V VBIAS = +4.5V/–4.5V 1.0 400 VDD = +15V, VSS = –15V C) p 0.5 200 N ( A) n IO V ( DD = +5V, VSS = –5V E CT 0 0 NJE I AKAG E V E DD = +12V, VSS = 0V L –0.5 –200 IS (OFF) + – I CHARG D (OFF) + – IS (OFF) – + –1.0 –400 ID (OFF) – + ID, IS (ON) ++ ID, IS (ON) – – –1.5 –600 0 20 40 60 80 100 120
006
–15 –10 –5 0 5 10 15
012
TEMPERATURE (°C) V
06815-
S (V)
06815- Figure 12. Leakage Currents vs. Temperature, Figure 15. Charge Injection vs. Source Voltage ±5 V Dual Supply Rev. D | Page 9 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY +12 V SINGLE SUPPLY ±5 V DUAL SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
