Datasheet ADG1201 (Analog Devices) - 8
DescriptionLow Capacitance, Low Charge Injection, ±15 V/+12 V iCMOS SPST in SOT-23
Pages / Page14 / 8 — ADG1201. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 200. 250. A = …
File Format / SizePDF / 418 Kb
ADG1201. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 200. 250. A = +25. DD = +15V. 180. VSS = –15V. VDD = +13.5V. 160. SS = –13.5V
ADG1201 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 200 250 A = +25 DD = +15V 180 VSS = –15V VDD = +13.5V 160 SS = –13.5V
ADG1201 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 200 250 T V A = +25
º
C DD = +15V 180 VSS = –15V VDD = +13.5V 160 V 200 SS = –13.5V ) TA = +125°C 140 ) 120 150 ANCE ANCE T T 100 T A = +85°C IS IS S V S DD = +15V VDD = +16.5V 80 V 100 SS = –15V VSS = –16.5V N RE N RE TA = +25°C O T 60 O A = –40°C 40 50 20
003 006
0
06576-
0
06576-
–18 –15 –12 –9 –6 –3 0 3 6 9 12 15 18 –15 –10 –5 0 5 10 15 SOURCE OR DRAIN VOLTAGE (V) SOURCE OR DRAIN VOLTAGE (V)
Figure 3. On Resistance vs. Source or Drain Voltage, Dual Supply Figure 6. On Resistance vs. Source or Drain Voltage, Different Temperatures, Dual Supply
450 600 TA = +25°C VDD = +12V 400 VSS = 0V 500 TA = +125°C 350 T ) ) A = +85°C V 300 DD = +5.5V 400 V SS = –5.5V ANCE 250 ANCE T T 300 IS IS S 200 S N RE N RE 200 O 150 O TA = –40°C TA = +25°C 100 100 50
004 007
0
06576-
0
06576-
–5 –4 –3 –2 –1 0 1 2 3 4 5 0 2 4 6 8 10 12 SOURCE OR DRAIN VOLTAGE (V) SOURCE OR DRAIN VOLTAGE (V)
Figure 4. On Resistance vs. Source or Drain Voltage, Dual Supply Figure 7. On Resistance vs. Source or Drain Voltage, Different Temperatures, Single Supply
450 200 TA = 25°C 150 VDD = +15V 400 VSS = –15V VDD = 12V 100 VBIAS = ±10V VDD = 10.8V V 350 SS = 0V V 50 SS = 0V ) A) p 0 300 ( NT –50 ANCE 250 –100 T VDD = 13.2V IS CURRE –150 S 200 VSS = 0V E –200 N RE 150 O AKAG –250 E L 100 –300 I –350 S (OFF) + – ID (OFF) + – 50 IS (OFF) – + ID (OFF) – +
005
–400
028
ID, IS (ON) + + ID, IS (ON) – – 0
06576-
–450
06576-
0 2 4 6 8 10 12 0 20 40 60 80 100 120 SOURCE OR DRAIN VOLTAGE (V) TEMPERATURE (ºC)
Figure 5. On Resistance vs. Source or Drain Voltage, Single Supply Figure 8. Leakage Current vs. Temperature, Dual Supply Rev. A | Page 8 of 14 Document Outline Features Applications Functional Block Diagram General Description Product Highlights Revision History Specifications Dual Supply Single Supply Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Test Circuits Terminology Outline Dimensions Ordering Guide
