Datasheet ADG1201 (Analog Devices) - 10
DescriptionLow Capacitance, Low Charge Injection, ±15 V/+12 V iCMOS SPST in SOT-23
Pages / Page14 / 10 — ADG1201. Data Sheet. VDD = 15V. VSS = –15V. 5.5. SOURCE/DRAIN ON. TA = …
File Format / SizePDF / 418 Kb
ADG1201. Data Sheet. VDD = 15V. VSS = –15V. 5.5. SOURCE/DRAIN ON. TA = 25ºC. ) E. DD = 12V. 4.5. VSS = 0V. SS O. NCE. IO T. ACI. 3.5. CAP. DRAIN OFF
ADG1201 Data Sheet VDD = 15V VSS = –15V 5.5 SOURCE/DRAIN ON TA = 25ºC ) E DD = 12V 4.5 VSS = 0V SS O NCE IO T ACI 3.5 CAP DRAIN OFF
ADG1201 Data Sheet 0 6 VDD = 15V –2 VSS = –15V 5.5 SOURCE/DRAIN ON TA = 25ºC 5 ) E –4 ) V (d F DD = 12V (p 4.5 VSS = 0V SS O –6 TA = 25ºC L NCE N A 4 T IO T –8 R ACI 3.5 SE CAP DRAIN OFF IN –10 3 –12
7 01
2.5 SOURCE OFF
19 0 0 6- 6-
–14
657 657 0
2
0
10k 100k 1M 10M 100M 1G 0 2 4 6 8 10 12 FREQUNCY (Hz) INPUT VOLTAGE (V)
Figure 15. Insertion Loss vs. Frequency Figure 18. Capacitance vs. Input Voltage, Single Supply
10 0 R V L = 10kΩ DD = +15V T –10 A = 25°C VSS = –15V V p-p = 0.63V NO DECOUPLING CAPACITORS ON –20 TA = 25ºC –30 1 ) B) –40 (% VDD = +5V, VSS = –5V, VS = +3.5V rms (d N R + R –50 S P HD V T DD = +15V, VSS = –15V, VS = +5V rms –60 AC 0.1 DECOUPLING CAPACITORS ON –70 –80
4 02
–90
025 6- 76- 57
0.01
06
–100
065
10 100 1k 10k 100k 100k 1M 10M 100M FREQUENCY (Hz) FREQUENCY (Hz)
Figure 16. THD + N vs. Frequency Figure 19. AC Power Supply Rejection Ratio (AC PSRR) vs. Frequency
6 VDD = 15V 5.5 VSS = –15V TA = 25ºC 5 ) F SOURCE/DRAIN ON (p 4.5 NCE A 4 T ACI 3.5 CAP 3 DRAIN OFF 2.5
18 0
SOURCE OFF
6-
2
657 0
–15 –10 –5 0 5 10 15 INPUT VOLTAGE (V)
Figure 17. Capacitance vs. Input Voltage, Dual Supply Rev. A | Page 10 of 14 Document Outline Features Applications Functional Block Diagram General Description Product Highlights Revision History Specifications Dual Supply Single Supply Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Test Circuits Terminology Outline Dimensions Ordering Guide
