Datasheet ADG1221, ADG1222, ADG1223 (Analog Devices) - 9
DescriptionLow Capacitance, Low Charge Injection, ±15 V/+12 V iCMOS Dual SPST Switches
Pages / Page16 / 9 — Data Sheet. ADG1221/ADG1222/ADG1223. TYPICAL PERFORMANCE CHARACTERISTICS. …
File Format / SizePDF / 451 Kb
Data Sheet. ADG1221/ADG1222/ADG1223. TYPICAL PERFORMANCE CHARACTERISTICS. 200. 250. TA = 25°C. VDD = +15V. 180. VSS = –15V. 160
Data Sheet ADG1221/ADG1222/ADG1223 TYPICAL PERFORMANCE CHARACTERISTICS 200 250 TA = 25°C VDD = +15V 180 VSS = –15V 160
Data Sheet ADG1221/ADG1222/ADG1223 TYPICAL PERFORMANCE CHARACTERISTICS 200 250 TA = 25°C VDD = +15V 180 VSS = –15V V 160 DD = +13.5V VSS = –13.5V 200 ) T 140 ) A = +125°C 120 150 T 100 A = +85°C SISTANCE VDD = +15V V SISTANCE DD = +16.5V 80 V 100 SS = –15V VSS = –16.5V N RE N RE TA = +25°C O 60 O TA = –40°C 40 50 20
003 006
0
06574-
0
06574-
–18 –15 –12 –9 –6 –3 0 3 6 9 12 15 18 –15 –10 –5 0 5 10 15 SOURCE OR DRAIN VOLTAGE (V) SOURCE OR DRAIN VOLTAGE (V)
Figure 4. On Resistance as a Function of VS (VD), Dual Supply Figure 7. On Resistance as a Function of VS (VD) for Different Temperatures, Dual Supply
450 600 TA = 25°C VDD = 12V 400 VSS = 0V 500 TA = +125°C 350 TA = +85°C ) V ) 300 DD = +5.5V V 400 SS = –5.5V 250 300 SISTANCE 200 SISTANCE N RE N RE O 150 O 200 TA = –40°C T 100 A = +25°C 100 50
004 007
0
06574-
0
06574-
–5 –4 –3 –2 –1 0 1 2 3 4 5 0 2 4 6 8 10 12 SOURCE OR DRAIN VOLTAGE (V) SOURCE OR DRAIN VOLTAGE (V)
Figure 5. On Resistance as a Function of VS (VD), Dual Supply Figure 8. On Resistance as a Function of VS (VD) for Different Temperatures, Single Supply
450 200 TA = 25°C 150 VDD = +15V 400 V V SS = –15V DD = 12V 100 VBIAS = ±10V 350 VDD = 10.8V VSS = 0V V 50 SS = 0V ) (Ω 300 (pA) 0 NT –50 250 –100 VDD = 13.2V SISTANCE 200 V –150 SS = 0V E CURRE –200 N RE O 150 –250 LEAKAG 100 –300 –350 IS (OFF) + – ID (OFF) + – 50 I
005
–400 S (OFF) – + ID (OFF) – +
018
ID, IS (ON) + + ID, IS (ON) – – 0
06574-
–450
06574-
0 2 4 6 8 10 12 0 20 40 60 80 100 120 SOURCE OR DRAIN VOLTAGE (V) TEMPERATURE (ºC)
Figure 6. On Resistance as a Function of VS (VD), Single Supply Figure 9. Leakage Current as a Function of Temperature, Dual Supply Rev. B | Page 9 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TERMINOLOGY TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
