Datasheet ADG1221, ADG1222, ADG1223 (Analog Devices) - 10
Description | Low Capacitance, Low Charge Injection, ±15 V/+12 V iCMOS Dual SPST Switches |
Pages / Page | 16 / 10 — ADG1221/ADG1222/ADG1223. Data Sheet. 150. 0.5. DD = +5V. A = 25ºC. 0.4. … |
Revision | B |
File Format / Size | PDF / 451 Kb |
ADG1221/ADG1222/ADG1223. Data Sheet. 150. 0.5. DD = +5V. A = 25ºC. 0.4. 100. VSS = –5V. VBIAS = ±4.5V. 0.3. DD = +15V. SS = –15V. 0.2. N (. 0.1. –50. CUR
ADG1221/ADG1222/ADG1223 Data Sheet 150 0.5 V T DD = +5V A = 25ºC 0.4 100 VSS = –5V VBIAS = ±4.5V V 0.3 DD = +15V V 50 ) SS = –15V A) C p p 0.2 ( N ( NT 0 IO 0.1 RE CT –50 JE 0 CUR N E I E V –0.1 DD = 12V –100 VSS = 0V AKAG E –0.2 L –150 CHARG –0.3 IS (OFF) + – ID (OFF) + – –200 V
0
IS (OFF) – + ID (OFF) – + DD = +5V
2 41 0
–0.4
0
V
4-
ID, IS (ON) + + ID, IS (ON) – – SS = –5V
4- 57
–250
657 06
–0.5
0
0 20 40 60 80 100 120 –15 –10 –5 0 5 10 15 TEMPERATURE (ºC) INPUT VOLTAGE (V)
Figure 10. Leakage Current as a Function of Temperature, Dual Supply Figure 13. Charge Injection vs. Input Voltage
300 300 V 250 DD = 12V V 15V DS t SS = 0V OFF V 15V DS tON 200 BIAS = 1/10V 250 12V SS t OFF 12V SS t ON A) p 150 ( NT 200 100 RE ) 50 ns CUR ( 150 E E 0 M TI AKAG E –50 100 L –100 IS (OFF) + – ID (OFF) + –
9
IS (OFF) – + ID (OFF) – + 50
1
–150
0 4-
45 0 57
–200
4- 06
0 20 40 60 80 100 120 0
657 0
TEMPERATURE (ºC) –40 –20 0 20 40 60 80 100 120 TEMPERATURE (ºC)
Figure 11. Leakage Current as a Function of Temperature, Single Supply Figure 14. tON/tOFF vs. Temperature
120 0 IDD PER CHANNEL VDD = +15V TA = 25ºC –10 VSS = –15V 100 TA = 25ºC –20 –30 80 ) ) (dB –40 (µA 60 TION –50 I DD A L V O –60 DD = +15V 40 IS VSS = –15V –70 V –80 DD = 12V 20 VSS = 0V
49 5 0
–90
02 4- 4- 57
0
657 0
–100
06
0 2 4 6 8 10 12 14 10k 100k 1M 10M 100M 1G LOGIC LEVEL, INx (V) FREQUENCY (Hz)
Figure 12. IDD vs. Logic Level Figure 15. Off Isolation vs. Frequency Rev. B | Page 10 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TERMINOLOGY TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
