Datasheet ADG1308, ADG1309 (Analog Devices) - 3
Description4-and 8-Channel ±15 V/+12 V Multiplexers
Pages / Page16 / 3 — ADG1308/ADG1309. SPECIFICATIONS DUAL SUPPLY. Table 1. Parameter. +25ºC. …
File Format / SizePDF / 364 Kb
ADG1308/ADG1309. SPECIFICATIONS DUAL SUPPLY. Table 1. Parameter. +25ºC. −40ºC to +105ºC. Unit. Test Conditions/Comments
ADG1308/ADG1309 SPECIFICATIONS DUAL SUPPLY Table 1 Parameter +25ºC −40ºC to +105ºC Unit Test Conditions/Comments
link to page 11 link to page 11 link to page 11 link to page 11 link to page 11 link to page 11 link to page 11 link to page 12 link to page 12 link to page 12 link to page 12 link to page 4 link to page 4 link to page 11
VDD = +15 V ± 10%, VSS = –15 V ± 10%, GND = 0 V, unless otherwise noted.1
Table 1. Parameter +25ºC −40ºC to +105ºC Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range VSS to VDD V On Resistance, RON 130 Ω typ VS = ±10 V, IS = −1 mA; see Figure 13 210 300 Ω max VDD = +13.5 V, VSS = −13.5 V On Resistance Match Between Channels, ∆RON 5 Ω typ VS = ±10 V, IS = −1 mA 10 Ω max On Resistance Flatness, RFLAT (On) 25 Ω typ VS = −5 V, 0 V, +5 V, IS = −1 mA 70 Ω max LEAKAGE CURRENTS Source Off Leakage, IS (Off ) ±1 nA typ VD = ±10 V, VS = −10 V; see Figure 14 ±50 nA max Drain Off Leakage, ID (Off ) ±1 nA typ VS = 1 V, 10 V; VD = 10 V, 1 V; see Figure 14 ±50 nA max Channel On Leakage, ID, IS (On) ±1 nA typ VS = VD = ±10 V; see Figure 15 ±50 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH ±0.005 μA max VIN = VINL or VINH ±0.1 μA max Digital Input Capacitance, CIN 5 pF typ DYNAMIC CHARACTERISTICS2 Transition Time, tTRANSITION 80 ns typ RL = 300 Ω, CL = 35 pF 130 190 ns max VS = 10 V; see Figure 16 tON (EN) 80 ns typ RL = 300 Ω, CL = 35 pF 100 120 ns max VS = 10 V; see Figure 18 tOFF (EN) 85 ns typ RL = 300 Ω, CL = 35 pF 100 150 ns max VS = 10 V; see Figure 18 Break-Before-Make Time Delay, tBBM 25 ns typ RL = 300 Ω, CL = 35 pF 10 ns min VS1 = VS2 = 10 V; see Figure 17 Charge Injection 2 pC typ VS = 0 V, RS = 0 Ω, CL = 1 nF; see Figure 19 Off Isolation 80 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 20 Channel-to-Channel Crosstalk 80 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 21 −3 dB Bandwidth 500 MHz typ RL = 50 Ω, CL = 5 pF; see Figure 22 CS (Off ) 5 pF typ f = 1 MHz, VS = 0 V CD (Off ) ADG1308 15 pF typ f = 1 MHz, VS = 0 V ADG1309 10 pF typ f = 1 MHz, VS = 0 V CD, CS (On) ADG1308 20 pF typ f = 1 MHz, VS = 0 V ADG1309 15 pF typ f = 1 MHz, VS = 0 V Rev. A | Page 3 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS ADG1308 TRUTH TABLE ADG1309 TRUTH TABLE TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
