Datasheet ADG1204 (Analog Devices) - 9
DescriptionLow Capacitance, Low Charge Injection, ±15 V/+12 V, 4:1 iCMOS Multiplexer
Pages / Page16 / 9 — Data Sheet. ADG1204. TYPICAL PERFORMANCE CHARACTERISTICS. 200. 250. A = …
RevisionC
File Format / SizePDF / 462 Kb
Data Sheet. ADG1204. TYPICAL PERFORMANCE CHARACTERISTICS. 200. 250. A = +25°C. DD = +15V. 180. VSS = –15V. VDD = +13.5V. 160. VSS = –13.5V
Data Sheet ADG1204 TYPICAL PERFORMANCE CHARACTERISTICS 200 250 A = +25°C DD = +15V 180 VSS = –15V VDD = +13.5V 160 VSS = –13.5V
Data Sheet ADG1204 TYPICAL PERFORMANCE CHARACTERISTICS 200 250 T V A = +25°C DD = +15V 180 VSS = –15V VDD = +13.5V 160 VSS = –13.5V 200 ) TA = +125°C 140 ) (Ω (Ω 120 150 ANCE T 100 T A = +85°C SISTANCE IS VDD = +15V VDD = +16.5V S RE 80 VSS = –15V V 100 SS = –16.5V N N RE O T 60 O A = –40°C TA = +25°C 40 50 20
010 006
0
04779-
0
04779-
–18 –15 –12 –9 –6 –3 0 3 6 9 12 15 18 –15 –10 –5 0 5 10 15 SOURCE OR DRAIN VOLTAGE (V) SOURCE OR DRAIN VOLTAGE (V)
Figure 4. On Resistance as a Function of VD (VS), Dual Supply Figure 7. On Resistance as a Function of VD (VS) for Different Temperatures, Dual Supply
450 600 TA = +25°C VDD = +12V 400 VSS = 0V 500 TA = +125°C 350 T ) ) A = +85°C V (Ω 300 DD = +5.5V (Ω 400 VSS = –5.5V 250 300 SISTANCE 200 SISTANCE RE RE N N O 150 O 200 TA = –40°C 100 TA = +25°C 100 50
004 007
0
04779-
0
04779-
–5 –4 –3 –2 –1 0 1 2 3 4 5 0 2 4 6 8 10 12 SOURCE OR DRAIN VOLTAGE (V) SOURCE OR DRAIN VOLTAGE (V)
Figure 5. On Resistance as a Function of VD (VS), Dual Supply Figure 8. On Resistance as a Function of VD (VS) for Different Temperatures, Single Supply
450 0.30 TA = 25°C VDD = +16.5V 400 V 0.25 SS = –16.5V V V V DD = 12V BIAS = +10V/–10V DD = 10.8V 350 V V SS = 0V SS = 0V 0.20 ) (Ω 300 A) 0.15 I n D, IS (ON) 250 ( E VDD = 13.2V 0.10 200 V SISTANCE I SS = 0V S (OFF) AKAG RE E N L 0.05 O 150 0 100 ID (OFF) 50 –0.05
005 008
0
04779-
–0.10
04779-
0 2 4 6 8 10 12 14 0 20 40 60 80 100 120 SOURCE OR DRAIN VOLTAGE (V) TEMPERATURE (°C)
Figure 6. On Resistance as a Function of VD (VS), Single Supply Figure 9. Leakage Currents as a Function of Temperature, Dual Supply Rev. C | Page 9 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TRUTH TABLE TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
