Datasheet ADG1204 (Analog Devices) - 10
Description | Low Capacitance, Low Charge Injection, ±15 V/+12 V, 4:1 iCMOS Multiplexer |
Pages / Page | 16 / 10 — ADG1204. Data Sheet. 0.20. 250. VDD = 13.2V V. 0.15. SS = 0V. VBIAS = … |
Revision | C |
File Format / Size | PDF / 462 Kb |
ADG1204. Data Sheet. 0.20. 250. VDD = 13.2V V. 0.15. SS = 0V. VBIAS = 10V/1V. 200. 0.10. D, IS (ON). DD = +12V, VSS = 0V. 0.05. 150. ID (OFF). IME (n
ADG1204 Data Sheet 0.20 250 VDD = 13.2V V 0.15 SS = 0V VBIAS = 10V/1V 200 0.10 I V D, IS (ON) DD = +12V, VSS = 0V A) 0.05 n ) 150 ( s E ID (OFF) 0 IME (n VDD = +15V, VSS = –15V AKAG T E 100 L –0.05 IS (OFF) –0.10 50 –0.15
009 015
–0.20
04779-
0
04779-
0 20 40 60 80 100 120 –40 –20 0 20 40 60 80 100 120 TEMPERATURE (°C) TEMPERATURE (°C)
Figure 10. Leakage Currents as a Function of Temperature, Single Supply Figure 13. Transition Times vs. Temperature
60 0 IDD PER CHANNEL VDD = +15V TA = +25°C –10 VSS = –15V 50 –20 TA = +25°C ) –30 40 VDD = +15V, VSS = –15V dB ( –40 A) µ TION –50 ( 30 I DD OLA –60 20 –70 OFF IS –80 10 VDD = +12V, VSS = 0V –90
011
–100
016
0
04779-
–110
04779-
0 2 4 6 8 10 12 14 10k 100k 1M 10M 100M 1G LOGIC, INX (V) FREQUENCY (Hz)
Figure 11. IDD vs. Logic Level Figure 14. Off Isolation vs. Frequency
6 0 SOURCE TO DRAIN VDD = +15V DRAIN TO SOURCE –10 VSS = –15V 4 TA = +25°C –20 TA = +25°C C) –30 p 2 N ( B) –40 IO d –50 S1 TO S2 CT K ( 0 V AL –60 NJE DD = +5V, VSS = –5V T I S E S V –70 S2 TO S4 DD = +12V, VSS = 0V –2 CRO –80 CHARG –90 –4 VDD = +15V, VSS = –15V –100
014
–110
017
–6
04779-
–120
04779-
–15 –10 –5 0 5 10 15 10k 100k 1M 10M 100M 1G VS (V) FREQUENCY (Hz)
Figure 12. Charge Injection vs. Source Voltage Figure 15. Crosstalk vs. Frequency Rev. C | Page 10 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TRUTH TABLE TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
