Datasheet ADG1211, ADG1212, ADG1213 (Analog Devices)
Description | Low Capacitance, Low Charge Injection ±15 V/+12 V iCMOS Quad SPST Switches |
Pages / Page | 16 / 1 — Low Capacitance, Low Charge Injection,. ±15 V/+12 V. CMOS Quad SPST … |
Revision | D |
File Format / Size | PDF / 380 Kb |
Low Capacitance, Low Charge Injection,. ±15 V/+12 V. CMOS Quad SPST Switches. Data Sheet. ADG1211/. ADG1212. /ADG1213. FEATURES
Low Capacitance, Low Charge Injection, ±15 V/+12 V
i
CMOS Quad SPST Switches Data Sheet ADG1211/ ADG1212 /ADG1213 FEATURES FUNCTIONAL BLOCK DIAGRAM 1 pF off capacitance S1 S1 S1 2.6 pF on capacitance IN1 IN1 IN1 D1 D1 D1 <1 pC charge injection S2 S2 S2 33 V supply range IN2 IN2 IN2 120 Ω on resistance D2 D2 D2 ADG1211 ADG1212 ADG1213 Fully specified at ±15 V, +12 V S3 S3 S3 No V IN3 IN3 IN3 L supply required D3 D3 D3 3 V logic-compatible inputs S4 S4 S4 Rail-to-rail operation IN4 IN4 IN4 16-lead TSSOP and 16-lead LFCSP D4 D4 D4 Typical power consumption: <0.03 µW SWITCHES SHOWN FOR A LOGIC 1 INPUT
04778-001
Figure 1.
Automatic test equipment Data acquisition systems Battery-powered systems Sample-and-hold systems Audio signal routing Video signal routing Communication systems GENERAL DESCRIPTION
The ADG1211/ADG1212/ADG1213 are monolithic complemen- The ADG1211/ADG1212/ADG1213 contain four independent tary metal-oxide semiconductor (CMOS) devices containing single-pole/single-throw (SPST) switches. The ADG1211 and four independently selectable switches designed on an iCMOS® ADG1212 differ only in that the digital control logic is inverted. (industrial CMOS) process. iCMOS is a modular manufacturing The ADG1211 switches are turned on with Logic 0 on the process combining high voltage CMOS and bipolar technologies. appropriate control input, while Logic 1 is required for the It enables the development of a wide range of high performance ADG1212. The ADG1213 has two switches with digital control analog ICs capable of 33 V operation in a footprint that no previous logic similar to that of the ADG1211; the logic is inverted on the generation of high voltage devices has been able to achieve. other two switches. The ADG1213 exhibits break-before-make Unlike analog ICs using conventional CMOS processes, iCMOS switching action for use in multiplexer applications. components can tolerate high supply voltages while providing Each switch conducts equally wel in both directions when on increased performance, dramatically lower power consumption, and has an input signal range that extends to the supplies. In the and reduced package size. off condition, signal levels up to the supplies are blocked. The ultralow capacitance and charge injection of these switches
PRODUCT HIGHLIGHTS
make them ideal solutions for data acquisition and sample-and- hold applications, where low glitch and fast settling are required. 1. Ultralow capacitance. Fast switching speed coupled with high signal bandwidth make 2. <1 pC charge injection. the devices suitable for video signal switching. 3. 3 V logic-compatible digital inputs: VIH = 2.0 V, VIL = 0.8 V. 4. No V iCMOS construction ensures ultralow power dissipation, L logic power supply required. 5. Ultralow power dissipation: <0.03 µW. making the devices ideally suited for portable and battery- 6. 16-lead TSSOP and 3 mm × 3 mm LFCSP packages. powered instruments.
Rev. D Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2005–2016 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TERMINOLOGY TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
