Datasheet ADG1211, ADG1212, ADG1213 (Analog Devices) - 10
Description | Low Capacitance, Low Charge Injection ±15 V/+12 V iCMOS Quad SPST Switches |
Pages / Page | 16 / 10 — ADG1211/ADG1212/ADG1213. Data Sheet. 0.30. 200. VDD = 12V V. 180. 0.25. … |
Revision | D |
File Format / Size | PDF / 380 Kb |
ADG1211/ADG1212/ADG1213. Data Sheet. 0.30. 200. VDD = 12V V. 180. 0.25. SS = 0V. VBIAS = 1V/10V. 12V SS T. 160. 0.20. ID, IS (ON). 140. 0.15. 120
ADG1211/ADG1212/ADG1213 Data Sheet 0.30 200 VDD = 12V V 180 0.25 SS = 0V VBIAS = 1V/10V 12V SS T 160 ON 0.20 ID, IS (ON) 140 0.15 120 15V DS TON 0.10 100 IS (OFF) TIME (ns) 80 LEAKAGE (nA) 0.05 12V SS TOFF 60 0 40 I 15V DS T D (OFF) OFF –0.05 20 –0.10
04778-013
0
04778-016
0 20 40 60 80 100 120 –40 –20 0 20 40 60 80 100 120 TEMPERATURE (
C) TEMPERATURE (
C)
Figure 10. Leakage Currents as a Function of Temperature, Single Supply Figure 13. TON/TOFF Times vs. Temperature
60 0 IDD PER CHANNEL VDD = +15V T –10 A = +25
C VSS = –15V 50 T –20 A = +25
C –30 40 VDD = +15V, VSS = –15V –40
µ
A) –50 ( 30 I DD –60 –70 20 OFF ISOLATION (dB) –80 –90 10 VDD = +12V, VSS = 0V –100 0
04778-011
–110
04778-017
0 2 4 6 8 10 12 14 10k 100k 1M 10M 100M 1G LOGIC, IN FREQUENCY (Hz) X (V)
Figure 11. IDD vs. Logic Level Figure 14. Off Isolation vs. Frequency
6 0 SOURCE TO DRAIN –10 VDD = +15V DRAIN TO SOURCE VSS = –15V 4 TA = +25
C –20 TA = +25
C –30 2 –40 –50 0 V –60 DD = +5V, VSS = –5V –70 VDD = +12V, VSS = 0V –2 CROSSTALK (dB) –80 CHARGE INJECTION (pC) –90 –4 V –100 DD = +15V, VSS = –15V –110 –6
04778-015
–120
04778-018
–15 –10 –5 0 5 10 15 10k 100k 1M 10M 100M V FREQUENCY (Hz) S (V)
Figure 12. Charge Injection vs. Source Voltage Figure 15. Crosstalk vs. Frequency Rev. D | Page 10 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TERMINOLOGY TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
